Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Using SubInterfaces with ASA 5510
Dear All,
I have ASA 5510, and I want to use one Ethernet port of it as like sub-interfaces in which I want it to have two IPs.
Somebody told me that I can configure something called virtual zones !
consulting your expertise, how can I do this?
Re: Using SubInterfaces with ASA 5510
Not sure about virutal zones, but the ASA can run in multiple context mode see the below link:-
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00808d2b63.shtml
Or you can create a trunked interface on the ASA and have muiltiple sub-interfaces based on dot1q.
HTH>
Mahmoud,
As Andrew mentioned, you probably want to setup subinterfaces like this:
interface GigabitEthernet0/2
no nameif
no security-level
no ip address
interface GigabitEthernet0/2.5
vlan 5
nameif admin
security-level 100
ip address 10.1.1.254 255.255.255.0
interface GigabitEthernet0/2.50
vlan 50
nameif sales
security-level 60
You can then treat the subinterfaces like regular interfaces (apply ACLs, NAT, etc.).
Hope that helps.
-Mike
279
