Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
V-LAN
Hi, I need to create three V-LANS configured on Subinterfaces of FW which will be connected with L2 Switch and same V-LANS I will create on L2 Swicth. Should the connection between Switch and FW be in Trunk mode or if its not be in Trunk mode then may i know why as all V-LAN traffic goes by Trunk mode as I assume. Pls clarify. Thanks
Hall of Fame Super Blue
Re: V-LAN
Ray
Yes, the switchport that the ASA connects into should be configured as an 802.1q trunk.
Jon
Community Member
Re: V-LAN
And what about the port of Cisco ASA FW, it should also be configured in Trunk mode.
279
