Very Strange PIX Firewall Issue
Hello All,
Today at our Datacenter there was a very strange issue. So we were seeing many drops with servers that we had on one of our many cirucits. Only one circuit was affected. After troubleshooting through everything I realized that the issue was PIX that we have on that circuit. When everything else except this PIX is connected in everything works fine. This has been our PIX for the last 3-4 years and has worked just fine. Out of nowhere now it basically takes down everything. No changes were made and this just happened out of nowhere. What I mean by it takes down everything is that we have basically a public switch with a few devices into it. All of these devices work 100% when I unplug the PIX from it however when I plug the PIX everything completely loses connection. By this I mean that 50% of pings to ALL devices including the PIX itself fail but again once I disconnect the PIX everything comes completely up again. Just to reiterate this has been our PIX for the last 3-4 years and no changes were made. This happened out of nowhere. Has anyone ever seen anything like this and do you think there is a way to fix or should we just simply replace?
Thanks so much in advance.
  • Firewalling
1 ACCEPTED SOLUTION
Hello John,
It is not a easy task to troubleshoot this performance issues.
I would like to see a show interface from the pix to check if there are any errors with the interfaces.
Julio
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Hello John,
Julio
Hello jcarvaja,
Thanks for the reply. I am not in the office now but I will get you this info tomorrow. Thanks again.
Thank You for your help, it turned out to be a Linux Server server that took down the network. Crazy Stuff, but thank you.
Hello John,
Great to hear that now everything is working fine.
Have a great day,
Julio
429
