VLAN on ASA 5510 and L2 Switch
Looking to impliment VLANS as per diagram.
ISP->Router-->ASA5510--->Switch(L2 2960).
Want to create some 25 VLANs and don't want to allow communication among VLANs.Just want to allow internet access to all of the VLANS.
How should I meet this??
Reg,
Sushil
Re: VLAN on ASA 5510 and L2 Switch
Sure is possible, lets see, asa5510 can support up to 50 VLANS with Base lisence and 100 VLANs with security plus lisence. You will have to use trunking and allocate a FE on the ASA for this. Assuming your 2960 is a 48 port switch, not a 24 port because you will need to acomodate 25 vlans with corresponding switchport vlan#s.
1-Create your 25 vlans in the switch
2-Allocate port on switch for 802.1q trunking to a allocated FE port on ASA
3-Create subinterfaces in ASA - define IP scheme for each interface
4-Define security level requirements for subinterfaces, you could use same security level on each subinterfaces and if you do not want comminication between them you can use"no same-security-traffic permit inter-interface" command. If comminication is
needed between hosts on different vlans it can be accomplish through acls.
5- for internet acces you could use your outside interface to PAT inside nets for outbound internet connections.
Example.
Assume you have 4 networks 2.2.2.0, 3.3.3.0, 4.4.4.0, 5.5.5.0
ASA5510
interface ethernet0/2
speed 100
duplex full
nameif LAN
security-level 50
no ip address
interface Ethernet0/2.2
vlan 2
nameif vlan2
security-level 50
ip address 2.2.2.1 255.255.255.0
interface Ethernet0/2.3
vlan 3
nameif vlan3
security-level 50
ip address 3.3.3.1 255.255.255.0
interface Ethernet0/2.4
vlan 4
nameif vlan4
security-level 50
ip address 4.4.4.1 255.255.255.0
interface Ethernet0/2.5
vlan 5
nameif vlan5
security-level 50
ip address 5.5.5.1 255.255.255.0
global (outside) 1 interface
nat(vlan2) 1 2.2.2.0 255.255.255.0
nat(vlan3) 1 3.3.3.0 255.255.255.0
nat(vlan4) 1 4.4.4.0 255.255.255.0
nat(vlan5) 1 5.5.5.0 255.255.255.0
Switch_2960:
vlan database
vtp transparent
vtp domain test_lab
vtp password cisco
vlan 2 name VLAN2_2.2.2.0/24
vlan 3 name VLAN3_3.3.3.0/24
vlan 4 name VLAN4_4.4.4.0/24
vlan 5 name VLAN5_5.5.5.0/25
etc....
Interface fastethernet0/48
Description trunk_Connection_ASA_Ethernet03
speed 100
duplex full
switchport mode trunk
switchport trunk allowed vlan 2,3,4,5 etc..
I think you got the idea..
Rgds
Jorge
Thanks Jorge thats really helpful.
Would like to know can I run IPSEC for site to site VPN for some of the VLANS.May be some 15 tunnels.
Yes you can run ipsec for some of the vlans. That should not be an issue.
Best Regards
Dinesh
(http://knowurtech.com)
Good cisco articles
Thanks guys,
One more question how should I propagate the VLAN to rest of the switches.
Say adding total 120 users to 25 VLANS.
Means 4 or 5 user in single Vlan.As my switch will be having 48 ports only.
Do I need to enable trunking between L2 switches.
How to achieve this?
Reg,
Sushil
Hi Sushil,
Since the Layer 3 interfaces of vlan are created on ASA , only l2 vlans needs to be created on the switches. Just create L2 vlan on the switches and you can extend the vlans to more switches.Just make sure that these switches are in same vtp domain and take care of the VTP more client/server or transparent etc. Yes you need to create trunk between two switches.
Please rate the post if you find it useful.
Best Regards
Dinesh
Good cisco articles
Thanks a lot Dinesh,
This is really helpful.I was looking for opinion which I got right from you guys.
Sushil
522
