Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Vlan on pix 525 running 7.0
I have a pix 525 running 7.0 software version.
The gigabit interface is configured in the following way:
interface gigabitethernet0/1
nameif housing
security-level 60
ip address x.x.x.x 255.255.255.0
I want a vlan to use the gigabit, does this conf correct?
interface gigabitethernet0/1.10
vlan 10
nameif myvlan
security-level 60
ip address y.y.y.y 255.255.255.0
On the switch that connect to the giga i allowed a trunk with housing native vlan
(i know traffic forwareded by physical interface is untagged)
1 REPLY
Bronze
Re: Vlan on pix 525 running 7.0
That configuration is correct. Packets destined for the y.y.y.y network (or routed out that interface) will go out tagged as vlan 60, and packets for x.x.x.x network (or routed out that interface) will be untagged, and go on the 'native' vlan of the trunk you have configured on the switch.
--Jason
Please rate this message if it helped solve some or all of your issue.
346
