Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Voice Gateway outside firewall, CUCM inside
If I have the voice-gateway for a CUCM outside the firewall, what NAT statement and port are needed for the configuration of the firewall?
Re: Voice Gateway outside firewall, CUCM inside
Hello Steven
Following URL lists the ports used by CUCM with various components:
www.cisco.com/en/US/docs/voice_ip_comm/cucm/port/6_0/60plrev1.pdf
Is there any access-restriction applied on the inside interface of a firewall ? If so, you will have to open up appropriate ports as listed on the pdf.. make sure you open UDP 16384-32767 for communication between voice gateway to CUCM on the outside interface, for return voice traffic..
you can just give a normal static statement, which does not nat the traffic.. eg, if the CUCM has 10.1.1.1 as ip, u can give
static (inside,outside) 10.1.1.1 10.1.1.1 netmask 255.255.255.255
or the other way around by natting the gateway IP address..
Hope this helps.. all the best.. rate replies if found useful.
Raj
Community Member
thanks for the pointer to the ports and the potential solution.
243
