Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
VOIP QOS ASA Issue
Hello Support,
We have two locations which each have an ASA. See attached for models. There are VOIP phones at Office 2, and basically all calls from the phone device 172.30.30.10 route through the phone device 192.168.8.10. The idea behind this design from the beginning was so that Office 2 could dial out from the same number as Office 1. Users at Office 2 are experiencing about 10-15 drops in call quality per day. Call completes, but there are time when users cannot hear the other end and then it just reconnects during the call. It's my understanding, that I will need QOS on all the devices in route which I have depicted in the diagram. Internet circuit at office 1 is 1000 Mb, and internet circuit at office 2 is 50 Mb. I have the below configured on the devices. Please advise if I'm missing anything, as calls continue to experience drops in service.
Office 2
ASA 5505
class-map VOIP
 match dscp ef
policy-map QOS
 class class-default
  shape average 1000000
policy-map global_policy
class VOIP
  priority
service-policy global_policy global
service-policy QOS interface outside
Office 1
ASA 5550
class-map VOIP
 match dscp ef
policy-map QOS
 class class-default
  shape average 10000000
 class VOIP
  priority
Cisco 3560
mls qos
interface GigabitEthernet0/1 (uplink to ASA 5550)
mls qos trust cos
interface GigabitEthernet0/3 (uplink to 2960)
mls qos trust cos
Cisco 2960
mls qos
access-list 101 permit ip any any
class-map match-all VOIP
 match access-group 101
policy-map QOS
 class VOIP
  set ip dscp ef
interface GigabitEthernet1/0/25 (uplink to IS Device)
 mls qos trust dscp
 service-policy input QOS
1 ACCEPTED SOLUTION
Hi,You can try setting
You can try setting priority queuing on the interfaces and verify the required inspect statements for h323 h225, h323 ras, skinny, sip is enabled already.... if not try with the below mentioned Qos on your firewalls and check if that solves the problem.....
Office 1:1000 Mbps
access-list voip_inside extended permit ip <other end voip subnet> <inside Voip Subnet>
access-list voip_outside extended permit ip <inside Voip Subnet> <other end voip subnet>
priority-queue inside
priority-queue outside
class-map voice-inside-class
 match access-list voip_inside
class-map voip-outside-class
 match access-list voip_outside
 class inspection_default
  inspect h323 h225
  inspect h323 ras
  inspect skinny
  inspect sip
policy-map outside-policy
 class voip-outside-class
  priority
policy-map inside-policy
 class voice-inside-class
  priority
policy-map ins-policy
 class class-default
  shape average 100000000
  service-policy inside-policy
policy-map out-policy
 class class-default
  service-policy outside-policy
service-policy ins-policy interface inside
service-policy out-policy interface outside
Office 2: 50 Mbps
access-list voip_inside extended permit ip any <inside Voip Subnet>
access-list voip_outside extended permit ip <inside Voip Subnet> any
  inspect h323 h225
  inspect h323 ras
  inspect skinny
  inspect sip
  priority
  priority
 class class-default
  shape average 5000000
 class class-default
Karthik
Hello, Pls answer the
Pls answer the following question.
How many MB do you want to give on each site based on the pipe to the ISP for Regular Data traffic?
jcarvaja
CCIE R&S 42930, 2-CCNP,JNCIS-SEC
Looking for a quick remote support session? Contact us at inetworks.cr
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Community Member
Hi jcarvaja, i'd like to give
Hi jcarvaja,
i'd like to give 97+% of the pipe on both ends. Free up about 1% of the internet line on both ends for phone traffic. So on Site 1 since they have 1000 Mb internet, I'd like to dedicate about 10 Mb to phone traffic, and on site has a 50 Mb connection, so I'd like to free up about .5 - 1 Mb for phone traffic, and the rest dedicated for data. I hope this best answers your question.
Office 1:1000 Mbps
  inspect h323 h225
  inspect h323 ras
  inspect skinny
  inspect sip
  priority
  priority
 class class-default
 class class-default
Office 2: 50 Mbps
  inspect h323 h225
  inspect h323 ras
  inspect skinny
  inspect sip
  priority
  priority
 class class-default
 class class-default
Karthik
Community Member
Thanks Karthnik. I'm on
Thanks Karthnik. I'm on vacation, but once I'm back I'll look to apply what you have. Thanks again!
513
