VPN Between ASA 5505 and SonicWall 4006 pro
I have a problem, when I try to create a VPN tunnel between Cisco ASA and SonicWall 4006. In Phase I, the tunnel is active, but when the ASA can't build the ipsec key and the phase II fails.
Phase I
1 IKE Peer: 200.30.146.8
Type : L2L Role : initiator
Rekey : no State : MM_ACTIVE
Phase II
IKEv1]: Group = 200.30.146.8, IP = 200.30.146.8, QM FSM error (P2 struct &0x391c990, mess id 0xc4c46cb5)!
Mar 23 17:19:06 [IKEv1]: Group = 200.30.146.8, IP = 200.30.146.8, construct_ipsec_delete(): No SPI to identify Phase 2 SA!
Mar 23 17:19:06 [IKEv1]: Group = 200.30.146.8, IP = 200.30.146.8, Removing peer from correlator table failed, no match!
I review all the parameters in ASA 5505 and SonicWall and I saw this link: http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008052c9d4.shtml
but I can't solve my problem.
Thank's so much!!
1 REPLY
Re: VPN Between ASA 5505 and SonicWall 4006 pro
Hi guillermo,
Is your ASA configured for ip address identity:
isakmp identity address
If it is this message indicates that somehow the traffic is coming "encrypted" to the asa but there is no SA created to decrypt it, go ahead and add the line that I mentioned and turn on "debug crypto isakmp 15" and try again. Post your debugs here if unsuccessful.
636
