VPN Connection permit only few machines
ray_stone
Hi, I have recently setup a remote VPN over ASA and its working fine. Now as per security concerned I want that client could able to use VPN connection by only their Laptops from outside Nework if they try to use like cyber cafe machines then It couldnt work. Is there any security which we can use to allow the machines to connect the remote VPN over the internet.Thanks..
andrew.prince
Level 10
Level 10
Ray,
If you are talking about the Cisco VPN client, the not really. if they have install the client - and have the information from the .pcf file - this can be used anywhere.
However - if you go down the WebVPN, Cisco Secure Desktop:-
1) Registry check - exists, does not exist, DWORD, String
2) File check - exists, does not exist, version, checksum
3) Certificate check - all the information
4) Windows version check - Win 2k/XP/Vista/9x
5) IP address check - range & mask
HTH.
