VPN connection problem
Hi all,
Friends, i have ASA 5505, configured everything right and works fine.
But i have a little trouble... When i try to connect from my network to another network using VPN client, VPN is connected but i can not enter inside network.
Earlier i have FreeBSD and i could connect without any problems, after that i changed FreeBSD to ASA 5505 i can not enter to this network via VPN client.
P.S. remote side is also ASA 5520, and from my home i could enter without problems.
Pls, help to resolve this problem
Kind regards
Giorgi
Re: VPN connection problem
First you check the pool range that must be different from the existing network. If it's not working, then u must check the ACL that you have apply. If it's also correct, then you should must be able to ping.
If the problem will still remain after modification, then I need the asa config. Let me know it's work or not.
i have network 10.0.0.0/24 and remote network is also same.
but remote ASA's VPN pool is 172.20.5.0/28... when i connected ip have my local ip addres 10.0.0.x and 172.20.5.2.
This may be problem why i can not enter in this network ?
When i connected i can not ping remote servers and hosts.
P.S. But earlier, when i had FreeBSD i could connect via VPN client.
Kind Reards
Giorgi Ninidze
Now i tested VPN client from my network.
Remote site is ASA 5510. Everyone could connect from outside world (via VPN client) except my network. Their ip network is 192.168.1.0/24...
I think have to change something in service-policy or creat ACL.
Any idea ?
Giorgi
Please, somebody advice me what i have to do ?
Kind Regards
Giorgi
146
