Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
VPN connection problem
I am facing problem while configuring Remote Access VPN on ASA 5520, i have gone through the wizard to configure the same, while trying to connect using vpn client but there is no connection
I debug crypto Isakm 129
and debug crypto isakm ipsec 129
the message appear when the client try to connect a bellow:
Nov 29 17:28:06 [IKEv1 DEBUG]: Group = training, IP = 10.10.100.201, sending delete/delete with reason message
Nov 29 17:28:06 [IKEv1]: Group = training, IP = 10.10.100.201, Removing peer from peer table failed, no match!
Nov 29 17:28:06 [IKEv1]: Group = training, IP = 10.10.100.201, Error: Unable to remove PeerTblEntry
when I run syslog server the warning and error messages :
11-30-2010 02:30:27 Local4.Warning 172.16.1.1 %ASA-4-713903: Group = training, IP = 10.10.100.201, Error: Unable to remove PeerTblEntry
11-30-2010 02:33:23 Local4.Error 172.16.1.1 %ASA-3-713902: Group = DefaultRAGroup, IP = 10.10.100.201, Removing peer from peer table failed, no match!
my VPN configuration is :
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map rmt-dyna-map 10 set security-association lifetime seconds 28800
crypto dynamic-map rmt-dyna-map 10 set security-association lifetime kilobytes 4608000
crypto dynamic-map rmt-dyna-map 30 set security-association lifetime seconds 28800
crypto dynamic-map rmt-dyna-map 30 set security-association lifetime kilobytes 4608000
crypto map rmt-dyna-map 10 ipsec-isakmp dynamic rmt-dyna-map
crypto map rmt-dyna-map interface outside
isakmp enable outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
tunnel-group training type ipsec-ra
tunnel-group training general-attributes
address-pool ippool
default-group-policy training
tunnel-group training ipsec-attributes
pre-shared-key *
isakmp keepalive threshold 30 retry 10
tunnel-group test type ipsec-ra
tunnel-group test general-attributes
default-group-policy test
tunnel-group test ipsec-attributes
pre-shared-key *
tunnel-group mygroup type ipsec-ra
tunnel-group mygroup general-attributes
default-group-policy mygroup
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd address 172.16.1.10-172.16.1.20 inside
dhcpd dns 217.66.226.8 4.2.2.2
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd enable management
dhcpd enable inside
any help if you plese
1 REPLY
Re: VPN connection problem
can you also share the output of "sh run group-policy"?
398
