VPN: Having problems allowing multiple connections
I have two road warriors that have broadband and are able to connect to the vpn with virtually no problems but when a third user who has a verizon card trys to connect it won't allow him to connect, unless i clear the crypto isakmp. Then he is able to connect but then the other users are not. I turned on debug to see what going on. can someone help!
Re: VPN: Having problems allowing multiple connections
Hi Eddie,
Issue command sh ver and check if you have enough VPN peer license.
husycisco,
This was the results of the 'sh ver'
It say's IKE peers Unlimited so I think I do
Cisco PIX Firewall Version 6.3(3)
Cisco PIX Device Manager Version 3.0(1)
Compiled on Wed 13-Aug-03 13:55 by morlee
CCX up 7 hours 18 mins
Hardware: PIX-506, 32 MB RAM, CPU Pentium 200 MHz
Flash i28F640J5 @ 0x300, 8MB
BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: ethernet0: address is 0050.54ff.b821, irq 11
1: ethernet1: address is 0050.54ff.b822, irq 10
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES-AES: Disabled
Maximum Physical Interfaces: 2
Maximum Interfaces: 2
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Limited
IKE peers: Unlimited
This PIX has a Restricted (R) license.
Serial Number: 480350848 (0x1ca19280)
Running Activation Key: 0xd0ca14d7 0xd9505ca8 0x029ca1e2 0x28f92281
Configuration last modified by enable_15 at 08:44:40.216 MST Thu Feb 7 2008
Eddie,
I suggest you to upgrade your IOS to 6.3(5) first. Second, make sure you have isakmp nat-traversal 20 issued in config
101
