VPN lab help
What extra would I need to practise creating VPN's in a lab at work rather that on the live equipment?
All I have is a Pix 515, 2 switches a 2950 and a 3550, and a couple of 2620 routers which have 2 WIC cards in each, but only 1 FE on each.
If this enough equipment to practise VPN's what would I need to use to achieve this etc?
Hall of Fame Super Blue
Re: VPN lab help
If you have a 2620 then you should be able to create an IPSEC site-to-site VPN between the 2620 and the pix. You would need the right feature set on the 2620 - have a look at Feature Navigator for the right IOS version.
Jon
Re: VPN lab help
Deleted - posted twice.
Jon
97
