VPN NAT Overlap subnets remote ASA interface does not reply
nickhesson
Hello all,
Not really a big problem, but not knowing the answer is killing me.  This is what I have:
Host 1 <-> ASA 5505 <-> VPN connection<-> ASA5510 <-> Host 2
Both hosts can reach each other without issues.  Ping, connect, no problem.
The problem is when one of the hosts trys to reach the inside interface of the remote ASA.  E.g. Host 1 trying to ping ASA5510 inside interface.  Again Host 1 and 2 have the same subnet address of 10.1.1.0/24.  I have configured the ASA 5505 to do the the NAT translations.
Here is the ASA 5505 config (the parts that matter):
ASA Version 8.2(5)
hostname ASA5505
interface Vlan1
nameif inside
security-level 100
ip address 10.1.1.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 192.168.100.102 255.255.255.252
access-list vpnACL extended permit ip 10.1.20.0 255.255.255.0 10.1.1.0 255.255.255.0
access-list VPNnat extended permit ip 10.1.1.0 255.255.255.0 10.1.30.0 255.255.255.0
access-list outacl extended permit icmp any any
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) 10.1.20.0  access-list VPNnat
static (outside,inside) 10.1.30.0 10.1.1.0 netmask 255.255.255.0
access-group outacl in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.100.101 1
crypto ipsec transform-set phase2 esp-aes esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 10 match address vpnACL
crypto map outside_map 10 set peer 172.16.14.50
crypto map outside_map 10 set transform-set phase2
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption aes
hash sha
group 2
lifetime 86400
management-access inside
tunnel-group 172.16.14.50 type ipsec-l2l
tunnel-group 172.16.14.50 ipsec-attributes
pre-shared-key *****
Here is the 5510 config:
: Saved
ASA Version 8.4(3)
hostname ASA5510
interface Ethernet0/0
nameif outside
security-level 0
ip address 172.16.14.50 255.255.255.252
interface Ethernet0/1
nameif inside
security-level 100
object network insidehosts
subnet 10.1.1.0 255.255.255.0
object network Site443
subnet 10.1.20.0 255.255.255.0
access-list VPNacl extended permit ip object insidehosts object outsidehosts
nat (inside,outside) source static insidehosts insidehosts destination static Site443 Site443
route outside 0.0.0.0 0.0.0.0 172.16.14.49 1
crypto ipsec ikev1 transform-set phase2p esp-aes esp-sha-hmac
crypto map outside_map 69 match address VPNacl
crypto map outside_map 69 set peer 192.168.100.102
crypto map outside_map 69 set ikev1 transform-set phase2p
crypto ikev1 enable outside
crypto ikev1 policy 10
encryption aes
hash sha
group 2
lifetime 86400
tunnel-group 192.168.100.102 type ipsec-l2l
tunnel-group 192.168.100.102 ipsec-attributes
ikev1 pre-shared-key *****
Again, this configuration works for all hosts on both subnets.  Except when hosts tries to ping the remote ASA's inside interface.
e.g. Host 1@10.1.1.50 pings/telnet to ASA2@10.1.30.1 fails.
Can anyone clue me as to why not?
Thanks for the time and support,
Nick
Jennifer Halim
NAT won't work on the ASA interfaces itself. NAT will only work for traffic passing through the ASA.
Jennifer Halim
Thanks Jennifer for the reply.  Is that just an ASA rule?  Or is there more of a technical reason why not?  Because I see using debug icmp trace, the at ASA's receive the ICMP requests.  But the ASA does not reply.
Again thanks for the reply.
Nick
Yes, you are absolutely correct. It is by design the ASA interface will not get NATed.
