Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
VPN Problem
I have set up a site to site vpn and i have a problem where return traffic is not hitting the access-list on the return journey. The access list is confgiured with the correct range. Has anyone come across this?
Cheers
Kev
Hall of Fame Super Blue
Re: VPN Problem
Hi Kev
Could you possibly post sanitised configs. Is there any chance that you are doing some NAT at the remote end that would make it miss the crypto access-list ?
Jon
Green
Re: VPN Problem
Maybe a little more information here. What device? What are you trying to accomplish? Is this an interface acl? Config?
Re: VPN Problem
Its NAT on a one to one i was being blind thanks for the help.
Cheers
Kev
130
