Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
VPN site-to-site & Remote connection
If I have 2 sites, both using Cisco877-SEC-K9 connect to Internet via ADSL with static IP. I can setup a VPN site-to-site connection between them via IPSec.
Is it possible for me to allow teleworker to remote connect to those sites (using VPN client)? I must create Easy VPN on each sites or what?
I read on Cisco 870 data-sheet that Cisco870 supports 10 VPN connection. That means 1 site-to-site & 9 remote VPN?
Thank you,
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: VPN site-to-site & Remote connection
Yes, you can terminate both site-to-site and remote access VPN tunnels on the same router. You can use EASY VPN if you want but you don't have to.
10 VPN tunnels means just that, it is not broken down into x number of site-to-site and x number of remote access. It just means you can have a total of 10 tunnels whichever type they are.
Jon
1 REPLY
Jon
216
