VPN Traffic Problem
i've got a strange Problem. I can establish a Tunnel between an PIX 515e (8.0.3) and an ASA Device 5510 7.0.6 Ping works, HTTP for example throws MSS Exceed on the ASA. PIX and ASA configured to allow mss-exceed via service Policy. The Data Size is always about 1443 Bytes. The sysopt tcpmss value is set t o1380 which should be enough for payload and IPSEC Header. The error Message says MSS Exceed MSS 1260 Data bytes 1443 ... ??? What the Hell can i do the reduce the payload. Changing the MTU size doesn't help.
I discover that the Problem arrives if i do an upgrade to ASA/PIXOS later than 7.0.6 because i have a second l2l tunnel to an Checkpoint device and if i upgrade the asa, this tunnel doesn't wokr for large Packets..
Any help is need...
greetings markus
  • Firewalling
1 REPLY
Silver
Re: VPN Traffic Problem
Check the config for allowing mss-exceed. Following is an example config:
access-list http-list permit ip any any
class-map http match
exit
tcp-map tmap
exceed-mss allow
exit
policy-map global_policy
class http
set connection advanced-options tmap
service-policy global_policy global
Also check for the traffic that is being denied and check if you have configured this for the right traffic.
85
