Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
VPN tunnel tears down after 24 hrs between ASA and Checkpoint
Hi Experts,
We have IPSec configured between Cisco ASA and Checkpoint NGX , the tunnel comes down once in a day and re-establishes after 2 hrs, we are facing this issue on a daily basis.
The SAs for phase1 and phase2 for ASA are 86400 secs and 3600 secs respectively .
Any suggestions would be of great help.
1 ACCEPTED SOLUTION
Silver
Re: VPN tunnel tears down after 24 hrs between ASA and Checkpoin
First of all, I made a mistake. In NGx R60
and higher, checkpoint has changed the location
of the user.def from $FWDIR/lib to $FWDIR/conf
directory. The new name of this file is
user.def.NGX_R60. Go figure.
These files are on the Checkpoint firewall,
not the ASA. The file is an ASCII file and
that you can read it with vi, cat or more.
CCIE Security
Silver
1- what version on the ASA? 7.x or 8.x?
2- what version of Checkpoint NGx? R60, R60A, R61, R62, R63 or R65?
Do you have any HFAs install?
3- Are you using traditional or simplified mode VPN?
4- Do you have PFS enable on the ASA not Checkpoint or vice versa?
Please check this.
5- What is the encrytion domain on the Checkpoint side? I need to know
ALL the network included behind the Checkpoint firewall
6- what is the interesting traffics behind the ASA? Need to know that
too
7- did you run "vpn debug trunc" to capture the $FWDIR/log/ike.elg file
and view it with IKEView.exe program. It will tell you exactly what
went wrong
8- if using simplified mode, did you use "permanent tunnel"?
9- did you tell checkpoint NOT to supernet everything in it encryption
domain
Please provide these information. It is hard to help you troubleshoot
a problem with so little information to go on.
CCIE Security
Thanks for responding. Since checkpoint is on the customer end, there is some delay in getting the information from the Checkpoint end.
Please could you let me know what is simplified and traditional mode of VPNs and which one is used frequently.
Deepali
Silver
Most of VPN is setup using Simplified mode.
Traditional mode is the legacy back to the
Checkpoint version 4.1. About 33% of VPN on
checkpoint is setup this way. However,
with NG and higher, Simplified mode is the
default.
We are observing that the tunnel fails more often now , 3-4 times a day and the tunnel comes up fine only after 5-6 hours sometime.
Deepali
Please see the answers inline.
ASA version 7.2
Checkpoint R61
simplified mode
Please check this.
PFS has not been enabled both on checkpoint and ASA
6- what is the interesting traffics behind the ASA? Need to know that too
and view it with IKEView.exe program. It will tell you exactly what went wrong
We have collected logs by enabling debug crypto engine and debug crypto isakmp when the tunnel goes down, please find the logs attached.
9- did you tell checkpoint NOT to supernet everything in it encryption domain
No domains are supernetted.
Please let me know if you need anymore info from our end.
Deepali
Silver
Please post the ike.elg file. I won't be to
offer much help without that file.
1- Pix 7.2 is buggy. Why don't you use version
7.0.7 instead?
2- why don't they upgrade the HFA on R61? It
should be at HFA_03.
3- when you say "No domains are supernetted."
How do you know? Without the ike.elg file,
I will know that for sure.
Silver
I think I've found the solution for you:
Look at this access-list:
access-list 114 extended permit ip host 192.168.170.33 host 172.20.14.10
access-list 114 extended permit ip host 192.168.170.33 host 172.16.2.26
access-list 114 extended permit ip host 192.168.170.38 host 172.16.2.26
access-list 114 extended permit ip 192.168.170.0 255.255.255.0 host 91.102.122.11
access-list 114 extended permit ip 192.168.170.0 255.255.255.0 91.102.122.12 255.255.255.252
Let say these are the hosts and network behind the checkpoint firewall.
Let assume that the network behind the checkpoint firewall is 172.20.14.0/24 and
172.16.2.0/24. Let also assume that the checkpoint also has another VPN with
another customer_X and that customer_X needs to access the whole network 172.20.14.0/24
and 172.16.2.0/24. Therefore, the checkpoint engineer put both network
17.20.14.0/24 and 172.16.2.0/24 into his local encryption domain. However, you do
not need to access the whole network, just a few hosts so he also put a couple of
hosts that you need into the encryption domain as well.
If the cisco side initiate the traffics, it should work because checkpoint
does not care. However, if checkpoint initiates the traffics, it will send the
whole /24 instead of a single host thus causing phase II quick mode error.
The ike.elg file can definitely confirm this.
SOLUTION:
in previous checkpoint version prior to NGx, you have to modify the IKE_largest_possible_network
from "true" to "false" and also the $FWDIR/lib/user.def file. In NGx, that is NOT
necessary. In the VPN community of your particular VPN tunnel, under advance mode, just select
"exchange key per host". That will fix your problem.
Good luck to you
CCIE Security
Thanks ! a ton.
I will try the solution you have suggested and update you soon.
Deepali
The customer has made the change you suggested on the firewall, we need to monitor the tunnel.
Please could you let me know where I can find the $FWDIR/lib/user.def file on ASA and can this be viewed through CLI .
Deepali
Silver
CCIE Security
Thank you so much, the problem is fixed and we see that the VPN is not going down any more.
2047
