vulnerabilities associated with ASA 5520
Hi everyone,
Scan results shows that ASA 5520 config for ipsec and anyconnect ikev2 has following vulnerability
Medium strength ciphers supported-----The remote host supports the use of SSL ciphers that offer medium strength encryption, which we currently regard as those with key lengths at least 56 bits and less than 112 bits.
Reconfigure the affected application if possible to avoid use of medium strength ciphers.
ASA is not using SSL anyconnect.
SSL config on ASL
ssl encryption aes256-sha1 aes128-sha1 3des-sha1 des-sha1 rc4-sha1 rc4-md5
ssl trust-point ASDM_TrustPoint0 outside
  anyconnect ssl dtls enable
  anyconnect ssl keepalive none
  anyconnect ssl rekey time none
  anyconnect ssl rekey method none
  anyconnect ssl compression deflate
vpn-tunnel-protocol ikev1 ssl-client
To fix this do i need to remove config --anyconnect ssl dtls enable??
Also currently FIPS is not enabled on ASA should i enable to get rid of scan results?
MAhesh
2 ACCEPTED SOLUTIONS
VIP Purple
With the following line in
With the following line in your config
You are running ciphers that are weak. You should remove any rc4- and des-ciphers. If compatibility permits it, you could also remove 3des as a legacy algorithm.
Depending on your version you could also enable the ciphers "dhe-aes128-sha1" and "dhe-aes256-sha1".
DTLS has nothing to do with this.
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
VIP Purple
yes, just set the new ciphers
yes, just set the new ciphers-string and you are ready. I didn't test that, but I would assume that any running connection with a removed cipher *could* get disconnected. But you don't want them anyway and when they reconnect they will pick one of the better ciphers.
Hi Mahesh, It seems that
Hi Mahesh,
It seems that still no updates from cisco against this vulnerability. They will release the new version of OS after fixing this vulnerability. You can go through the below mentioned link in detail.
http://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20140605-openssl
Karthik
VIP Purple
 Hi Karsten,i checked my ASA
Hi Karsten,
i checked my ASA i have below options
ssl encryption aes256-sha1 ?
configure mode commands/options:
  3des-sha1        Indicate use of 3des-sha1 for ssl encryption
  aes128-sha1      Indicate use of aes128-sha1 for ssl encryption
  des-sha1         Indicate use of des-sha1 for ssl encryption
  dhe-aes128-sha1  Indicate use of dhe-aes128-sha1 for ssl encryption
  dhe-aes256-sha1  Indicate use of dhe-aes256-sha1 for ssl encryption
  null-sha1        Indicate use of null-sha1 for ssl encryption (NOTE: Data is NOT encrypted if this cipher is chosen)
  rc4-md5          Indicate use of rc4-md5 for ssl encryption
  rc4-sha1         Indicate use of rc4-sha1 for ssl encryption
so below Config will take care of all the weak ciphers?
5520(config)# ssl encryption aes256-sha1 dhe-aes128-sha1 dhe-aes256-sha1
and i can do this on fly as it should not cause any outage.?
I can simply remove current ssl encryption config and replace it with above config?
Best Regards
MAhesh
VIP Purple
 Hi Karsten, Many thanks for
Hi Karsten,
Many thanks for answering my post.
It was pretty hard for me to find answer for this over the internet.
Best Regards
Mahesh
VIP Purple
Another config that I forgot,
Another config that I forgot, but that also could be found by an assessment, is the accepted SSL/TLS-version of the ASA. This is the default:
asa# sh run all ssl
ssl server-version any
Here you should change the setting to only accept TLSv1:
ssl server-version tlsv1-only
At least on up-to date operating systems I haven't seen any compatibility-issues with that.
 Thanks Karsten for more
Thanks Karsten for more update on this.
Best Regards
Mahesh
1188
