Wan and lan address the same
Just a query really,
Is it best to set my routers lan address the same as its external address when setting up with an ASA?
I have been told to do this but I would of thought keeping it a private address on the subnet would be better.
Ash
  • Firewalling
1 REPLY
VIP Green
This is not possible.  If you
This is not possible.  If you set your outside interface IP to (lets say) 1.1.1.1/30 and then try to set your inside interface to 1.1.1.1 you will get an error message stating something like it is already assigned to another interface (don't remember the exact message).  So you would have to have different IP addresses for each interface on the ASA (that includes subinterfaces.
In transparent mode you can set one management interface IP that will be on the same subnet as both your inside and outside networks.
Please remember to select a correct answer and rate helpful posts
-- Please remember to rate and select a correct answer
17
