WAN2 Failover
Hi all
I configured my ISA 550 for two WAN Ports, 1 is the main port with the IP 62.2.208.170 and the other Port (GE7) is configured as shown below as active failover
Security Application Configuration Utility - Mozilla Firefox_2013-08-16_10-33-01.png
The Latency Time for the Switch over is configured to 3 seconds
Security Application Configuration Utility - Mozilla Firefox_2013-08-16_10-34-19.png
the "WAN2" Port acts as DHCP Client which will be served by the second Internet Router
Security Application Configuration Utility - Mozilla Firefox_2013-08-16_10-36-43.png
and finally the Link Detection is based on pinging the gateways  (for WAN2 its the Routers internal IP 192.168.1.1)
Security Application Configuration Utility - Mozilla Firefox_2013-08-16_10-38-39.pngAdministrator CWindowssystem32cmd.exe - ping  192.168.1.png
The Failover works fine, but if unplug the WAN Cable(WAN1) i can't reach the WAN2 Connection
which means on the second WAN2 Port i have no internet connection
If plug the second Router directly to the internal LAN (192.168.1.x) everything works fine
any ideas?
Thanks for your help
Re:WAN2 Failover
Could you post the config please?
Sent from Cisco Technical Support Android App
Re:WAN2 Failover
Hello Anthony
Thanks for your reply
Attached you'll find the file or shoud i post it directly here?
Re:WAN2 Failover
Hello Anthony
Du you have receive my answer?
Any clue why it dosen't work
219
