Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Web access to switch in DMZ issue
when we try to connect to the web interface we get this in the logs Dropping TCP packet from dmz:smswitch.internal/80 to outside:cox.home/50206, reason: MSS exceeded, MSS 1260, data 1430
Re: Web access to switch in DMZ issue
Are you running 7.x? there seems to be workaround.. check this link.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00804c8b9f.shtml
Rgds
Jorge
Running 8.03 and tried that no joy.
Running 8.03
Robert, did you follow the example in the link using service-policy to activate the policy map created and apply it on outside interface? and using the keyword exceed-mss allow ?
I did some other search and found this is the only way to make this work even on version 8.0 as this is only done through policy framework class-map etc..
also on your original post you indicated this only happens on only a particular weblink , lookin at the log cox.home ? do you know the actual link dns name?
try this script and add it to your global policy, replace server_ip with the destination dmz host ip address.
access-list http-list permit tcp any host server_ip eq 80
class-map http
match access-list http-list
tcp-map tmap
exceed-mss allow
policy-map global_policy
class http
set connection advanced-options tmap
Rgds
Jorge
I did that previously and it didn't work. As for the DNS it is a switch and the switch does not have a dns entry. We access it by IP.
130
