Webmail not opening from inside IPs
Dear All,
We are unable to access webmail from inside ips using https://mail.companyname .  but we can access same thing from outside internet.
We use IP from our pool public IP for PAT as well as this webmail natting.
Is there any way we can access webmail from inside ips
we have asa 8.2 (1)
1 ACCEPTED SOLUTION
Re: Webmail not opening from inside IPs
Shibu,
These U-Turn x-lates may cause issue later on and may become very hard to manage, troubleshoot and maintain. These are hacks that are used to get things working that are not configured as they should.
My suggestion would be to configure your inside DNS server properly so that it returns the private ip address for the name mail.company.com
-KS
Shibu,
When you ping mail.company name from the inside hosts what do you get? The inside IP of webmail or outside IP of webmail?
Where is your DNS server?
Is this an internal DNS server?
Why doesn't it resolve to the inside IP of webmail?
On the browser issue http://inside_ip_address/exchange and see if it loads (I am assuming it is exchange).
If it does then pls. change the inside DNS server to hand out the inside IP address when computers want to resolve mail.company
-KS
Dear Kusankar,
Thanks for the reply.
Please find my answers.
I get outside IP of webmail when i ping mail.company.net.
In PCs we have local server as DNS server . in the DNS server we have given our ISP dns severs IP in forweded list.
How to do this DNS handout ?
Please find below some partial configuration of my ASA.
dns-guard
interface Ethernet0/0
nameif outside
security-level 0
ip address *.186 255.255.255.252
interface Ethernet0/1
nameif BACKUP
security-level 0
ip address *.202 255.255.255.248
interface Ethernet0/2
nameif INSIDE
security-level 100
ip address 10.10.10.10 255.255.255.0
access-list outside_access_in extended permit tcp any host 94.200.* eq https
global (outside) 1 interface
global (outside) 3 94.*
global (BROADCAST) 2 10.20.2.11-10.20.2.15 netmask 255.255.255.0
nat (INSIDE) 0 access-list INSIDE_nat0_outbound
nat (INSIDE) 2 access-list INSIDE_BROADCAST
nat (INSIDE) 3 access-list ROUTE_ADSL
nat (INSIDE) 1 0.0.0.0 0.0.0.0
static (INSIDE,outside) 94.* CASServer2 netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 94.* 1 track 1
route BACKUP 0.0.0.0 0.0.0.0 94.* 254
policy-map type inspect dns migrated_dns_map_1
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ftp
inspect esmtp
class class-default
flow-export event-type all destination 10.10.2.16 10.10.2.26
policy-map my-ips-policy
class my-ips-class
ips inline fail-open
Who manages your inside DNS server? Is this Microsoft DNS server?  It needs to be done there.
Create a zone file for your domain and add "A" records for all the sites that you host. Like
ftp.mycompany.com
mail.mycompany.com
www.mycompany.com
Make sure mail.mycompany.com >>>point to 10.10.10.x
-KS
Hello Shibu,
I hope you are doing great, this is a very common issue. You can use one of the following options:
1-Create a U turning config, say that the static for your server is
    static (inside,outside) netmask 255.255.255.255
You can do another one as this
    static (inside,inside) netmask 255.255.255.255
    global (inside) 1 interface
    same-security-traffic permit intra-interface
2-Change the IP address on the DNS server, say for the domain name for your Webmail instead of resolving to the public, resolve to the private. That will remain locally.
Any of those options can work for you, if you have any questions regarding any of these options let us know, we will be more than glad to help you.
Mike
Mike
Dear both ,
Thanks again for your kind help.
I tried the suggested first option but still i am unable to access webmail from inside
static (INSIDE,outside) 94.*.*. CASServer2 netmask 255.255.255.255
static (INSIDE,INSIDE)  94.*.*.  CASServer2 netmask 255.255.255.255
Please help further to sort out this issue.
Thanks in advance
Hello Shibu,
Would you please paste the output of the following command?
packet-tracer input inside tcp 10.10.10.12 1025 443
Thanks!
Mike
Mike
Dear ,
Please find below the trace
ASA-5510-1# packet-tracer input INSIDE tcp 10.10.7.20 1025 94.X 443
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
static (INSIDE,INSIDE) 94.*.* CASServer2 netmask 255.255.255.255
  match ip INSIDE host CASServer2 INSIDE any
    static translation to 94.*.*
    translate_hits = 0, untranslate_hits = 365
NAT divert to egress interface INSIDE
Untranslate 94.*.*/0 to CASServer2/0 using netmask 255.255.255.255
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: IDS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type:
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: NAT
Subtype:
Result: DROP
Config:
  match ip INSIDE any INSIDE any
    dynamic translation to pool 1 (No matching global)
    translate_hits = 161, untranslate_hits = 0
Result:
input-interface: INSIDE
input-status: up
input-line-status: up
output-interface: INSIDE
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
ASA-5510-1#
Latest trace
ASA-5510-1# packet-tracer input INSIDE tcp 10.10.7.20 1025 94.* 443
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 3
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
static (INSIDE,INSIDE) 94.* CASServer2 netmask 255.255.255.255
    translate_hits = 0, untranslate_hits = 420
Untranslate 94.*/0 to CASServer2/0 using netmask 255.255.255.255
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: IDS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type:
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: NAT
Subtype:
Result: DROP
Config:
    translate_hits = 194, untranslate_hits = 0
Result:
input-status: up
output-status: up
Action: drop
ASA-5510-1#
Seems you are doing it well, for somehow the firewall is not seeing the global (INSIDE) 1 interface
Would you please do a clear xlate and make sure that the global (INSIDE) 1 interface is in the configuration?
Mike
Mike
Shibu,
-KS
Dear both,
thanks for your suggestions.
I tried both options and both are working fine for me. but as a security measure i have adopted internal DNS method.
601
