Websense not enabled
I believe I set thing up correctly on the c880 and I get this "DISABLED" for websense. Anybody know how to enable it?
ip inspect name TEST http urlfilter
ip urlfilter server vendor websense 10.x.x.x
TESTSTORE#sh ip urlfilter config
Websense URL Filtering is DISABLED
Primary Websense server configurations
Websense server IP address Or Host Name: 10.x.x.x
Websense server port: 15868
Websense retransmission time out: 6 (in seconds)
Websense number of retransmission: 2
Secondary Websense servers configurations
Other configurations
Allow Mode: ON
System Alert: ENABLED
Audit Trail: DISABLED
Log message on Websense server: DISABLED
Truncate Hostname: DISABLED
Truncate Script-parameters: DISABLED
Maximum number of cache entries: 5000
Maximum number of packet buffers: 200
Maximum outstanding requests: 1000
Re: Websense not enabled
Brent,
Where is the IP Address 10.x.x.x located. Can you ping the 10.x.x.x ip address from the router through the right interface. If you want to source the URLFilter traffic from a specific interface, you can use the below command to achieve it.
ip urlfilter source-interface xxxxxxx
Also, make sure that the server is listening on the default port of 15868.
Arul
*Pls rate if it helps*
I can telnet to port 15868 on the websense server from a machine behind the router so I know if can connect. on the fa 4 interface I have "ip inspect NMMFW out" I have also tried "ip inspect NMMFW in" and neither work but in my head I'm thinking it should be outbound requests that are inspected.
It's the "Websense URL Filtering is DISABLED" that troubles me.
Brent,
I have seen this message before when the router is not able to access the websense server. Thanks for the confirming that you can telnet to the server from your LAN.
1. Can you telnet from the router itself
2. Show ip route for 10.x.x.x address
I want to make sure that the router can access the server.
Arul
I had to allow access from my core to the IP range of the tunnel interfaces on my spokes.
Seems to work fine now.
Brent,
Glad to know its working.
Arul
410
