Weird One Way VPN tunnel issue
Site A ASA5550 with vlan1, vlan2, and vlan3 <~~ Headquarter
Site B ASA5510 with vlan1
Site C ASA5505 with vlan1
Site A is a HQ and we have Site-to-Site VPN set for all sites with IPsec IKEv1 IPsec
Site A <--> Site B
Site A <--> Site C
Problem is on Site A HQ to Site B. For some reason VPN tunnel only establishes in one direction Site B to Site A but not Site A to Site B. When I logout the Site-to-Site VPN for Site A <-> Site B, there is no way for Site A to ping or connect to any server to Site B unless Site B ping or establish connections to Site A first, then Site A can ping or connect to Site B afterwards. The get around right now is I will need to ask someone from SIte B to ping Site A vlan1, vlan2, and vlan3 so that I can connect from Site A to Site B. All ASA is on the latest 8.4(3) version.
Site A <~> Site C works perfect fine without any probelm!! When I logout the Site-to-Site VPN for Site A <~> SIte C, the VPN tunnel established right away from either Site A to Site C or Site C to Site A.
Any suggestion on what should I look for before posting any configurations?
Thank you in advance. =)
First, please check whether you have a static route pushing site B traffic toward to default gateway on Site "A " ASA5550.
if that does not help, please copy your config on the forum for easy of trouble shooting from ASA5550.
Rizwan Rafeek
Thanks for your quick reply rizwanr74! Yes we do have static routes setup on Site A ASA5550 and both Site B and Site C outside interface are there with Site A Gateway IP on it.
Can you check the crypto ACL configuration on both sides and paste it in here so we can take a look at it?
Julio
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Thanks for your reply Julio. What command should I type in to show just the cryptop ACL configuration? I'm doing my best to show just the information you guys are looking for instead of the whole configuration file.
Under the crypto maps, you will see a match x.x.x.x ( where the x.x.x is the ACL that we are looking for)
We need both sites ACL (Branch and Site C)
Julio
Re: Weird One Way VPN tunnel issue
Is that what you are looking for? THANKS!!!
Site A HQ ASA
crypto map outside_map 3 match address outside_cryptomap_2
crypto map outside_map 3 set peer (Site B ISP IP)
crypto map outside_map 3 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 3 set reverse-route
crypto map outside_map 5 match address outside_cryptomap_3
crypto map outside_map 5 set peer (Site C ISP IP)
crypto map outside_map 5 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
Site B Branch ASA
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set peer (Site A ISP IP)
crypto map outside_map 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 set reverse-route
crypto map outside_map 3 set peer (Site C ISP IP)
Site C Branch ASA
crypto map outside_map0 1 match address outside_cryptomap
crypto map outside_map0 1 set peer (Site A ISP IP)
crypto map outside_map0 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map0 1 set reverse-route
crypto map outside_map0 2 match address outside_cryptomap_1
crypto map outside_map0 2 set peer (Site B ISP IP)
crypto map outside_map0 2 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map0 2 set reverse-route
Now on the ASA on Site A, please get the following
show run access-list outside_cryptomap_2
Now on the ASA on Site B, please get the following
show run access-list address outside_1_cryptomap
Site A HQ ASA
access-list outside_cryptomap_2 extended permit ip object-group DM_INLINE_NETWORK_11 object-group DM_INLINE_NETWORK_12
Site B Branch ASA
show run access-list outside_1_cryptomap
access-list outside_1_cryptomap extended permit ip object-group DM_INLINE_NETWORK_3 object-group SiteA-Network
Thank You!!
Hello IT,
ASA HQ Site A
On the Site A HQ ASA
Can you look for the configuration of this Object group DM_INLINE_NETWORK_12, Is this the network on the other site ( Site B) ?
Julio
Julio,
DM_INLINE_NETWORK_12 is only exited on Site A HQ ASA under outside_cryptomap_2
Source: Site A vlan1, Site A vlan2, Site A vlan3
Destination: Site B Network
Service: IP
I don't see any DM_INLINE_NETWORK_12 under Site B ASA. I believed DM_INLINE_NETWORK_12 was created automatically by using the ASDM wizard (some one else created long ago)
Thanks!
On Site A:
Please do the following:
packet-tracer input inside tcp x.x.x.x (Host ip on vlan A  site A) 1025 x.x.x.x (Host on other site of the tunnel-SiteB) 80
Julio
Site A HQ ASA:
packet-tracer input inside tcp x.x.x.x (VLAN1 IP on Site A) 1025 x.x.x.x (Host IP on Site B) 80
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   SiteB-network 255.255.0.0     outside
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: FILTER
Subtype: filter-ftp
Result: ALLOW
Config:
Phase: 5
Type: FILTER
Subtype: filter-url
Result: ALLOW
Config:
Phase: 6
Type:
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (inside,outside) source static DM_INLINE_NETWORK_8 DM_INLINE_NETWORK_8   destination static DM_INLINE_NETWORK_10 DM_INLINE_NETWORK_10
Static translate x.x.x.x (VLAN1 IP Address)/1025 to x.x.x.x (VLAN1 IP Address)/1025
Phase: 8
Type: VPN
Subtype: encrypt
Result: ALLOW
Config:
Phase: 9
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 10
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 11
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 644050669, packet dispatched to next module
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
On the packet tracer we can see is hitting a static rule, thing that should not happen!
Can we see the show run static, show run nat, sh run global.. And the ACLs for the nat 0( you will see a nat statement with an ID of 0 holding an ACL, I would like to see that acl-Show run acl xxxx (name)
Julio,
I tired show run-config static and show run-config global but both doesn't work... not sure why... I did not see any NAT 0 on my configure file or what exact command do I need to type in to find out? Please see below for everything I found related to NAT and ACL
Thanks again for all of your help!
Site A ASA show run nat
object network inside-network
nat (inside,outside) dynamic outside-defaultnat
access-list inside_nat0_outbound extended permit ip object-group DM_INLINE_NETWORK_2 object-group DM_INLINE_NETWORK_3
access-list inside_nat0_outbound extended permit ip object-group DM_INLINE_NETWORK_8 object-group DM_INLINE_NETWORK_10
Yes, the nat is properly configured, can you check the show run route?
There got a be a route going to the DM_INLINE_NETWORK_10 going to the outside ( it my be a route outside 0.0.0.0 0.0.0.0)
Can you confirm that?
Julio
Julio,
Site A ASA show run route
route inside inside-network 255.255.252.0 10.255.255.254 1
route inside x.x.x.x (VLAN 1 IP) 255.255.0.0 10.255.255.254 1
route inside x.x.x.x (VLAN 2 IP) 255.255.0.0 10.255.255.254 1
route inside x.x.x.x (VLAN 3 IP) 255.255.0.0 10.255.255.254 1
route outside Site B-network 255.255.0.0 x.x.x.x 1 (Site A Host)
route outside Site C-network 255.255.0.0 x.x.x.x 1 (Site A Host)
That's the thing I don't understand.. Site C network got similar setting as Site B on Site A ASA and it is working fine... =(
Thanks!
Yes, I understand what you mean. Can you check the transform-set used on the Site A with the Site B transform set?
Julio
Julio,
What command do you want me to type in to check on the transform set?
Thants the thing.. I don't think the probelm is on the site-to-site VPN settings because the tunnel works fine as long as Site B established the connections first by Pinging/connectiong to anything from Site A. Site B and Site C are using the same Site to site VPN Group Policy on Site A ASA.
Thanks!
Hello IT,
Correct, but the thing is the packet tracer shows that everything is working fine on this site (A). So my next question would be:
Is site B receiving the traffic?
For that you can do a capture from one host on site A to one host on site B
access-list test permit ip host_A_ip host_b_ip
access-list test permit ip host_b_ip  host_A_ip
capture capin access-list test interface inside
You should do this configuration on both ASAS.
Then do a Show cap capin on both ASAs, and provide the output.....
Julio
Julio,
I did the following on both ASA
Site A ASA HQ
Access-list test permit ip host x.x.x.x (Site A Host IP) host x.x.x.x (Site B Host IP)
Access-list test permit ip host x.x.x.x (Site B Host IP) host x.x.x.x (Site A Host IP)
Capture capin access-list test interface inside
Site B ASA Branch
then type in show cap capin on both ASA and get the following results.
Result of the command: "show cap capin"
0 packet captured
0 packet shown
Anything am I missing?
Did you send some traffic from Site A Host IP to the host on site B???
You should get some traffic at least on Site A?
Julio
Julio,
I changed the IP to the following, did the ping /t between and get the following response.
Site A ASA HQ
Access-list test permit ip host x.x.x.x (Site A My PC IP) host x.x.x.x (Site B Server IP)
Access-list test permit ip host x.x.x.x (Site B Server IP) host x.x.x.x (Site A My PC IP)
Site B ASA Branch
Site A ASA HQ
   1: 16:40:23.785588 (Site A My PC IP).51262 > (Site B Server IP).3389: . ack 227846090 win 253
   2: 16:40:24.644757 (Site A My PC IP)> (Site B Server IP): icmp: echo request
   3: 16:40:24.788624 (Site A My PC IP).51262 > (Site B Server IP).3389: . ack 227846143 win 258
   4: 16:40:25.645810 (Site A My PC IP)> (Site B Server IP): icmp: echo request
3706 packets captured
Site B ASA Branch
show cap capin
   1: 08:31:37.574692 (Site B Server IP).3389 > (Site A My PC IP)..51262: P 3045221942:3045221995(53) ack 1733105712 win 255
   2: 08:31:37.837526 (Site A My PC IP).> (Site B Server IP):: icmp: echo request
   3: 08:31:37.837725 (Site B Server IP): > (Site A My PC IP).: icmp: echo reply
   4: 08:31:37.954860 (Site A My PC IP)..51262 > (Site B Server IP):.3389: . ack 3045221995 win 254
Hello IT.
On the capture we can see that the Site B is receiving the traffic from site A, then that traffic is being decrypted sent to the inside interface to the host, The host replies and the packet never reaches the Site A, that is our problem here,
I think the fastest way to solve this issue would be seeing the configuration of boths ASAs site A and Site b, you can change some of the parts of the configuration due to security purposes.
That will makes this troubleshooting ticket  faster
Julio
Julio,
1. Site B Branch is receiving the traffic from Site A HQ
2. Site B Branch decrypted the traffic and then sent to the Site B Branch inside interface to the host
3. The host from Site B Branch replied the packet never reaches to Site A HQ
In the other words.
1. (Site B Server PC) is receiving traffic (ping for example) from (Site A My PC IP)
2. (SIte B Server PC) decrypted the traffic (ping) and then sent it to the Site B Branch inside interface to the host
3. (SIte B Server PC) replied never reached to (Site A My PC IP)
Is that what you means? Can you explain more about it? I don't really understand.
Is that possible I can just PM the configuration files from two sites?
THANKS!
Hello IT,
Yes, that is what happening, we are not seeing the traffic getting into the inside interface of siteA.
That is why I would like to check both ASAs configuration.
Julio
Julio,
I am going to PM you the configuration for Site B now.. and Site A late today!!
Thanks again for all yoru help!
IT
Please Check PM!
Thanks!!!
Hello IT,
ok I will!
784
