weird static route problem
on a test environment I have 2 static routes with access-lists to match.
both used to work, now only one of them connect...
adding a 3rd static\ACL with same command is working
the difference - the one that won't connect uses the outside interface IP, the other 2 use other IPs on the subnet.
see attached config.
Green
Re: weird static route problem
You need to use the keyword "interface" when using the ip address assigned to the outside interface.
static (inside,outside) tcp interface 951 192.168.200.2 951 netmask 255.255.255.255
this change is working for port 951
when I try to add a 2nd port on the same outside interface (using another static command & adding it to ACL) both are not working.
is there a limit of 1 port per IP?
Green
This should work fine.
static (inside,outside) tcp interface 952 192.168.200.2 952 netmask 255.255.255.255
static (inside,outside) tcp interface 953 192.168.200.2 953 netmask 255.255.255.255
etc.
this is what I did but with ports 951 & 25
is it possible that smtp has some different impact?
what about access-list - same as in 951?
94
