What if LAN failover link down?
I have two ASA running active/standby mode through LAN failover link. What if the LAN failover link is down, what will happen?
Thanks.
  • Firewalling
Everyone's tags (5)
The standby ASA should still see the active ASA is functional over the other links.  If this doesn't happen, you will get a split brain situation where both ASA's are active.
If failover Link goes down failover will not occur since it is monitored through other interfaces also.But if in that case failover occurs then all the connections are not replicated to the secondary firewall after switching.All connections are dropped and new connections are established for the traffic through the firewall (newly active).
552
