What is the difference between static and nat/global Commands
One more question. What is the point of the static command given that you have the nat/global nat commands instead? In what scenarios would you use the static command and when would you use nat/global commands?
Dan
1 REPLY
Hall of Fame Super Blue
Re: What is the difference between static and nat/global Command
Dan
See previous answer in original thread.
Jon
281
