Will capture Command Cause Any Impact?
hi all,
i've got few ASA 5510 currently in production that i want to capture some packets. i tried to look for docs or link if the capture command will cause any effect or impact on the ASA performance but i only saw this doc in cisco and some cisco white papers.
https://supportforums.cisco.com/docs/DOC-17345
could someone confirm on this? thanks in advance.
Everyone's tags (4)
2 ACCEPTED SOLUTIONS
My recomendation is make sure you use it only when you needed.
Captures will take CPU to run and Memory to store the information captured so make sure you only use it while troubleshooting.
I do remember once a customer was having 90 % CPU but he had like 5 captures running on the ASA, Circular buffer and catching a lot of stuff.
Note: If you are capturing traffic from 2 end-stations and you know there is no much traffic going on there then you should not be aware of something. Nothing will happen.
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.
Any question contact me at jcarvaja@laguiadelnetworking.com
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Super Bronze
I tend to use the packet capture a lot in the ASA. Mostly in the cases where the customer/user doesnt give a good description on what the problem is.
I use it on pretty much every model we have. ASAs, PIXs and FWSMs. To this day I have not run into any problems using the packet capture on the ASAs even multiple of them running at one time. I might have 1-3 captures active on a single device depending on the customer network in question.
So I would imagine that you wont run into any problems unless your device is already on its limit of resources.There was some discussion here recently that I think mentioned some problem related to capturing traffic that was caused by a bug.
- Jouni
Cheers,
Julio Carvajal
hey julio,
thanks for your feedback! so far, cpu's quiet.
i just want to check one instance only, so i guess it wouldn't hurt to fire this command.
# sh cpu usage
CPU utilization for 5 seconds = 2%; 1 minute: 2%; 5 minutes: 2%
# sh ve
Cisco Adaptive Security Appliance Software Version 8.2(5)
Device Manager Version 6.2(3)
Compiled on Fri 20-May-11 16:00 by builders
System image file is "disk0:/asa825-k8.bin"
Config file at boot was "startup-config"
up 114 days 3 hours
Hardware:   ASA5510, 256 MB RAM, CPU Pentium 4 Celeron 1599 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Super Bronze
- Jouni
jouni,
thanks for joining in and sharing a personal tip!
this gave me a confidence boost to try this out.
Hello John,
Exactly no worries at all
But remember this feature is used for troubleshooting purposes no need to let it running if you do not needed.
And just to be safe make it as Specific as Possible . That's the keyword.
Cheers,
Julio Carvajal
284
