Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Wireless access point using home base router?
So I want to use my WRT54GL with DDWRT standard firmware and I want to use it as my wireless access point.
I have a Cisco ASA firewall and I want to connect the WRT54GL to it.
The firewall is providing DHCP and routing to different network.
How do I setup the WRT54GL??  Having great deal of trouble configuring it to talk with my firewall...   Just wanted the WRT54GL to act as a access point (like a wireless switch) and nothing else!
Or is there a way to setup WRT54GL to access point mode only?  It seems that if I connect the firewall to the WAN port of the WRT54GL router, I will have to create another network...  which i dont want, as I want both firewall and wireless to be on same network.
Do I connect firewall to the WAN port on the WRT54GL? Any hint?
154
