Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ZBF Class-map and different way of doing them
Hi People just though i would ask a question on how to set up a ZBF. (question at the end of example config's)
i have been playing with this for a while now and like to get advice over what way is the recomended way of doing multiple matchs
ok we we all know the basic
class-map type inspect match-any ZBF_CM_ICMP
match protocol icmp
policy-map type inspect ZBF_PM_EXTERNAL->DMZ
class type inspect ZBF_CM_ICMP
  inspect
and then the ZP dont need to show, this is a simple map using nbar fair enough
then we could a mulitiple matches
class-map type inspect match-any ZBF_CM_STD_DMZ_PORTS
match protocol icmp
match protocol http
match protocol dns
match protocol https
policy-map type inspect ZBF_PM_DMZ->EXTERNAL
class type inspect ZBF_CM_STD_DMZ_PORTS
  inspect
Ok still easy to understand but now come the bit that a little more copmplex non NBAR matches
ip access-list extended AL_RDP_PORT
permit tcp any any eq 3389
class-map type inspect match-all ZBF_CM_RDP
match access-group name AL_RDP_PORT
class type inspect ZBF_CM_RDP
  inspect
This config is now using an access list because NBAR dosent have the protocol in it then map the AL to the CM then CM to PM. next is example is what i setup to get more non NBAR ports and only for 1 host
ip access-list extended AL_HOST_IP_IN
permit ip any host 11.11.11.11
ip access-list extended AL_ISATAP
permit 41 any any
ip access-list extended AL_TEREDO
permit udp any any eq 3544
class-map type inspect match-ANY ZBF_CM_DirectAccess_Protocols
description Nested Class Map
match access-group name AL_ISATAP
match access-group name AL_TEREDO
class-map type inspect match-ALL ZBF_CM_APP_IN
match access-group name AL_HOST_IP_IN
match access-group name ZBF_CM_DirectAccess_Protocols
class type inspect ZBF_CM_APP_IN
  inspect        (or pass with rule for other direction)
THis is what i setup and it works not for this example but the rule flow i then was having issues with DMVPN and ZBF (turned out to be an iso bug annoying me) but i used CiscoCP to setup the ZBF automaticly forthe DMVPN and it ZBF rule where  same proceduare as below.
permit 41 any any
class-map type inspect match-ANY CM_ISATAP
class-map type inspect match-ANY CM_TEREDO
match class-map CM_ISATAP
match class-map CM_TEREDO
  inspect
So what Cisco CP did was make yet another level of nesting rather then the match-all class map having the match access list command then made a cm with access list then the main class map had only other match class maps in it..
QUESTION:
Why did CiscoCP do the extra nesting
both ways worked but i would like to know why the cisco CP did the same thing with the other layer of CM did it do this for best practise or dose this make changed later easier i cant understand whats the advange to doing it this way... but if there is a valid reason then ill great jjust trying to understand.
thanks
regards
A very sore headed
Dave
431
