ZBF URL filtering Issue
Hello. I have the following problem. I try to implement the url filtering feature on a cisco 2811 router and whenever i enable the parameter map patterns the router retuns (after some time)
%Unable to compile obj regex...
My config is
parameter-map type urlfpolicy local URLFILTER
alert off
block-page message "THE REQUEST WAS BLOCKED BY YOUR ROUTER FIREWALL"
parameter-map type urlf-glob ALLOW-URL
pattern *.cisco.com
pattern cisco.com
parameter-map type urlf-glob DENY-URL
pattern *
class-map type urlfilter match-any ALLOW-URL
match  server-domain urlf-glob ALLOW-URL
class-map type urlfilter match-any DENY-URL
match  server-domain urlf-glob DENY-URL
class-map type inspect match-all INSPECT-HTTP
match protocol http
policy-map type inspect urlfilter URL-FILTER
parameter type urlfpolicy local URLFILTER
class type urlfilter ALLOW-URL
  allow
class type urlfilter DENY-URL
  reset
  log
policy-map type inspect IN-OUT
class type inspect VPN-TRAFFIC
  inspect
class type inspect INSPECT-HTTP
  inspect
  service-policy urlfilter URL-FILTER
class type inspect INTERNET-TRAFFIC
  inspect
class class-default
  drop
The result is that the router blocks ALL webpages without giving a block page message. Any help would be greatly appreciated.
Everyone's tags (4)
SOLVED!!!!
All needed was a router reload!!!!!
I have same problem. Reboot router don't help me. Firewall allow all traffic and blocked url too.
1056
