ZBF with IPv6 tunnel (HE/Sixxs) doesn't work when CEF is enabled
I recently reworked the firewall config in our office to also filter the self zone, and since then, I'm experiencing issue with our IPv6 tunnel uplinks (both  hurricane electric or sixxs).
The tunnel config :
interface Tunnel4
no ip address
zone-member security zone_wan
ipv6 address 2001:470:1F08:AAAA::2/64
ipv6 enable
tunnel source Loopback0
tunnel mode ipv6ip
tunnel destination 216.66.80.26
interface Loopback0
ip address 212.1.1.1 255.255.255.248
( 212.1.1.1 is part of a range routed to this router via another link, also in the zone_wan )
The relevant part of the zbf config :
ip access-list extended acl_v6tunnels
remark IPv6 uplinks ip6 in ip tunnel
permit 41 host 216.66.80.26 any
permit 41 any host 216.66.80.26
class-map type inspect match-any cm_v6tunnels
match access-group name acl_v6tunnels
policy-map type inspect pm_wan_to_self
description Policy for zone wan to zone self
class type inspect cm_gw_svc_vpn
  pass
class type inspect cm_v6tunnels
  pass
class type inspect cm_icmp6_echo
  inspect
class type inspect cm_icmp_echo
  inspect
class class-default
  drop
policy-map type inspect pm_self_to_wan
description Policy for zone self to zone wan
  pass
  pass
class type inspect cm_full_ip_gw_inspect
  inspect
class class-default
  drop
zone-pair security zp_wan_to_self source zone_wan destination self
service-policy type inspect pm_wan_to_self
zone-pair security zp_self_to_wan source self destination zone_wan
service-policy type inspect pm_self_to_wan
If I try to ping the other end of the tunnel for example, the forward packet are getting out, but the return packets are somehow blocked ...  They seem to match the cm_v6tunnels ACL in the return direction but never get to the 'ipv6 stage' (a debug ipv6 packet never shows them).
And the curious part is that if I disable IPv6 CEF ( no ipv6 cef globally ), then traffic starts flowing, both from/to the router itself (trying to ping various stuff) and from/to the hosts on the lan that are on the subnet router through that link.
If I remove the two zone-pairs, then it works as well.
So what is going on ???
Running without self fw on the wan and running without CEF both don't seem like solutions ...
Cheers,
    Sylvain
Do you see any kind of FW logs when you turn on the ip inspect log drop-pkt?
Mike
Mike
No, nothing.
On the class type subcommand drop, change it to drop log. This should log all your dropped packets that match this class.
421
