ZBFW and SIP problems
Hi GUYS,
Please help me..
I have experiencing problems with SIP phones behind firewall running on CIsco 887 VA-M.
I got these messages :
  5 02:43:37.439: %AIC-4-SIP_PROTOCOL_VIOLATION: SIP protocol violation (Mandatory header field missing) -  dropping udp session 192.168.33.120:5061 203.111.37.20:5060 on zone-pair in-out-zone class cmap-in-out-base
Jul  5 02:43:40.035: %AIC-4-SIP_PROTOCOL_VIOLATION: SIP protocol violation (Mandatory header field missing) -  dropping udp session 192.168.33.117:5060 203.111.37.20:5060 on zone-pair in-out-zone class cmap-in-out-base
I have downgraded software to 151-4.M6 and greated the policy to skip those checkings but no any improvements
My config is
boot-start-marker
boot system flash:c880data-universalk9-mz.151-4.M6.bin
boot-end-marker
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address 192.168.33.1 192.168.33.99
ip dhcp excluded-address 192.168.33.150 192.168.33.254
ip dhcp pool 1
network 192.168.33.0 255.255.255.0
default-router 192.168.33.1
dns-server 8.8.8.8
ip dhcp pool `
ip cef
ip domain name ues
ip name-server 8.8.8.8
no ipv6 cef
license udi pid CISCO887VA-M-K9 sn FGL171725DT
controller VDSL 0
class-map type inspect match-all cmap-manage
match access-group 23
class-map type inspect match-any cmap-in-out-ALL_allowed
match access-group 150
class-map type inspect match-any cmap-in-out-base
match protocol https
match protocol http
match protocol dns
match protocol ftp
match protocol pop3
match protocol citrix
match protocol citriximaclient
match protocol icmp
match protocol smtp
match protocol pptp
match protocol gopher
match protocol sip
match protocol h323
match protocol sip-tls
policy-map type inspect allow_all
class type inspect cmap-in-out-ALL_allowed
  pass
class class-default
  drop
policy-map type inspect pmap-out-in-manage
class type inspect cmap-manage
  pass
class class-default
  drop
policy-map type inspect pmap-in-out
class type inspect cmap-in-out-base
  inspect
  pass
class class-default
  drop
zone security in
zone security out
zone-pair security in-out-zone source in destination out
service-policy type inspect pmap-in-out
zone-pair security out-self-zone source out destination self
service-policy type inspect pmap-out-in-manage
zone-pair security out-in-zone source out destination in
service-policy type inspect allow_all
interface Ethernet0
no ip address
shutdown
no fair-queue
interface ATM0
no ip address
no ip route-cache
load-interval 30
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
switchport access vlan 100
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
no ip address
interface Vlan100
ip address 192.168.33.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
zone-member security in
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
zone-member security out
encapsulation ppp
ip tcp adjust-mss 1350
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname
ppp chap password 0 673569
ppp pap sent-username
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list FOR_NAT interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended FOR_NAT
permit ip 192.168.33.0 0.0.0.255 any
ip access-list extended KILL-TFTP
deny   udp any eq tftp any
permit ip any any
access-list 150 permit ip any any
access-list 150 remark TEMP
line con 0
no modem enable
line aux 0
line vty 0 4
login local
transport input ssh
end
Thanks a lot!
  • Firewalling
1 ACCEPTED SOLUTION
Re: ZBFW and SIP problems
Try to do disable inspection of protocol-violation for sip, using this config:
class-map type inspect sip SIP_VIOLATION_CLASS
match protocol-violation
policy-map type inspect sip SIP_VIOLATION_POLICY
class type inspect sip SIP_VIOLATION_CLASS
allow
  inspect
  service-policy sip SIP_VIOLATION_POLICY
allow
  inspect
Thanks Andrew - unfortunately cannot to try it now we have desided to turn inspection off and it works fine now for SIP phones.
362
