Zone Base Forewall for VPN connections does not work after IOS upgrade
Hi all,
We use cisco router 2911 as corporate gateway - there is Zone Based Firewall implemented - I upgraded IOS to last version (15.2(2)T1) - originaly version 15.1(4)M1 - to solve issue with Anyconnect connections (bug CSCtx38806) but I found that after upgrade the VPN users are not able to communicate with sources in other zones.
More specific
WebVPN use this virtual template interface
interface Virtual-Template100
description Template for SSLVPN
ip unnumbered GigabitEthernet0/1.100
zone-member security INSIDE
There are other zones VOICE, LAB, ...
In the policy any connection is allowed (used inspection of icmp, tcp and udp) from INSIDE zone to VOICE or LAB zone
After VPN connection I am able to reach resources in INSIDE zone (which is the most important), but not in other zones. Before upgrade it worked.
Once I changed zone in Virtual-Template interface to VOICE, I was able to reach sources in VOICE zone but not in any other. I searched more and found the stateful firewall is not working for connections from VPN as ping is blocked by policy on returning way - it means by policy VOICE->INSIDE, once I allowed communication from "destination" zone to INSIDE zone - the connections started to work, but of cause it is not something I want to setup.
Does anybody has the same experiance?
Pavel
1 REPLY
It seems to me I should add one importatant note - if client is connected directly in INSIDE zone, he can reach resources in other zones without any issue - so the problem is only when the client is connected by VPN - not in ZBF policy setup.
Pavel
276
