Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
lap
Community Member
Zone-Based Firewall and self zone issues in a DMVPN environment
I am getting crazy trying to understand and configure outside access to our customer router with Zone-Based Firewall.
Until now the customer was running IOS classic firewall and I decide to configure Zone-based firewall as it will give more flexibility.
The customer has a DMVPN network and the HUB router is a Cisco 2921 with following image: c2900-universalk9-mz.SPA.150-1.M1.bin and Security license.
I have configured the following Zone-pair and traffic flows betwen this zones is working find:
zone security INSIDE_LAN
zone security OUTSIDE_INTERNET
zone security DMVPN
zone-pair security INSIDE_OUT source INSIDE_LAN destination OUTSIDE_INTERNET
zone-pair security DMVPN_INSIDE_OUT source DMVPN destination OUTSIDE_INTERNET
zone-pair security DMVPN-TO-LAN source DMVPN destination INSIDE_LAN
But I have a real issue trying to reproduce the effect of the following Outside access-list (Inbound) on outisde interface used in the IOS classic Firewall with Zone-Based Firewall:
ip access-list extended OUTSIDEACL
permit icmp any any echo-reply
permit icmp any any traceroute
permit icmp any any time-exceeded
permit icmp any any unreachable
permit gre any any
permit udp any any eq non500-isakmp
permit udp any any eq isakmp
permit esp any any
deny   ip any any
I know I should use the self zone and I have also done that:
class-map type inspect match-all OUT-TO-SELF
match access-group name OUTSIDEACL  //I am using the ACL that I was using for IOS classic FW
class-map type inspect match-any SELF-TO-OUT
match protocol tcp
match protocol udp
match protocol icmp
policy-map type inspect OUT-TO-SELF
class type inspect OUT-TO-SELF
  pass
class class-default
  drop log
policy-map type inspect SELF-TO-OUT
class type inspect SELF-TO-OUT
  inspect
class class-default
  drop log
zone-pair security OUT-To-Self source OUTSIDE_INTERNET destination self
service-policy type inspect OUT-TO-SELF
zone-pair security Self-TO-OUT source self destination OUTSIDE_INTERNET
service-policy type inspect SELF-TO-OUT
Traffic initiated from the router (TCP,ICMP,UDP) is ok  and inspected but from OUT to self I have a real issue:
I loose my EIGRP neighbors cause the policy-map OUT-TO-SELF in denying ISAKMP from spokes (HUB router outside IP: 90.10.10.2):
FW-6-DROP_PKT: Dropping Other session 100.10.10.2:500 90.10.10.2:500 on zone-pair OUT-To-Self class class-default due to  DROP action found in policy-map with ip ident 0
No packets are matching the class-map OUT-TO-SELF:
policy exists on zp OUT-To-Self
Zone-pair: OUT-To-Self
  Service-policy inspect : OUT-TO-SELF
    Class-map: OUT-TO-SELF (match-all)
      Match: access-group name OUTSIDEACL
      Pass
       0 packets, 0 bytes
    Class-map: class-default (match-any)
      Match: any
      Drop
        414 packets, 55828 bytes
Futhermore no match in the access-list:
Extended IP access list OUTSIDEACL
    10 permit icmp any any echo-reply
    20 permit icmp any any echo
    30 permit icmp any any traceroute
    40 permit icmp any any time-exceeded
    50 permit icmp any any unreachable
    60 permit gre any any
    70 permit udp any any eq non500-isakmp
    80 permit udp any any eq isakmp
    90 permit esp any any
    100 permit udp any eq ntp any eq ntp
    110 deny ip any any
Do you have any idea why I am running in this issue? I guess I have misconfigured something but I thing the self-zone is not that easy to understand!
Laurent
Re: Zone-Based Firewall and self zone issues in a DMVPN environm
Hi Laurent,
What's happening is interesting. What happens when you change the action for the class-map OUT-TO-SELF to inspect instead of pass?
Also, in the access-list you are matching, try matching just one access-list entry, that is, modify the access-list to look like below and see if it makes any difference:
permit udp any any
Let me know how it goes!!
Thanks and Regards,
Prapanch
lap
Community Member
Hi Prapanch,
Thank you for your post.
What  I did is to reload the router and then there was match in the  OUTSIDEACL:
     70 permit udp any any eq non500-isakmp (2 matches)
     80 permit udp any any eq isakmp (8 matches)
     90 permit esp any any (541 matches)
     110 deny ip any any
Here is the new config:
  match access-group name Test
  pass
  class class-default
   drop log
   pass
  class class-default
   drop log
ip access-list extended Test
  permit tcp any any
  permit udp any any
  permit icmp any any
  permit eigrp any any
but  one of the eigrp neighbor is comming up and down and the FW is droping  connection form the router to OUTSIDE:
%FW-6-DROP_PKT: Dropping Unknown-l4 session  90.10.10.2:0 100.10.10.2:0 on zone-pair Self-TO-OUT class SELF-TO-OUT  due to  Invalid Segment with ip ident 0
Sep 22 10:43:38.183  UTC: %FW-6-LOG_SUMMARY: 11 packets were dropped from 90.10.10.2:57880  => 100.10.10.2:53 (target:class)-(Self-TO-OUT:SELF-TO-OUT)   *****Don't what DNS port  53 is doing there***
*Sep 22 10:39:27.507 UTC:  %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 10.2.0.2 (Tunnel1) is down:  retry limit exceeded
*Sep 22 10:39:31.567 UTC: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor  10.2.0.2 (Tunnel1) is up: new adjacency
Actually I  find out that this log : %FW-6-DROP_PKT: Dropping Unknown-l4 session  90.10.10.2:0  100.10.10.2:0 on zone-pair Self-TO-OUT class SELF-TO-OUT due to  Invalid  Segment with ip ident 0 means ESP protocol 50. So I had  permit esp any any to the Test access-list and that was find:
Extended  IP access list Test
     10 permit tcp any any
     20 permit udp any any (93 matches)
     40 permit eigrp any any
     50 permit esp any any (76 matches)
So  I have concluded the following and correct me please if I am wrong:
1-  In my first problem whre I needed to reload the router to get some  match in the OUTSIDEACL is because the IPsec SA exchange was already  made when I configured the ZBF policies and ZBF will only affect new  connection, not existing connections. Maybe I could have done a: clear  crypto sa.
2- As was the  case with classical stateful  inspection, router-generated           traffic is limited to TCP, UDP, ICMP, and complex-protocol inspection  for           H.323 so you have to do a pass for esp in order to build the tunnel  up.
I attach some rules regarding self-zone:
Please Rate if it helps!
Laurent
Hi Laurent,
1) Clearing the ipsec sa could have helped and is a good suggestion but ideally it should not really be necessary. I am saying this because i have seen all of this working without the need to clear the tunnel, previously.
2) That's an interesting point you put forward and have not really had a chance to try it out. I have seen inspection work for protocols such as ESP as well and according to me, the inspect action also should work for ESP. Though inspection does do deep packet inspection for protocols, it also is used to allow return traffic by creating a session entry for sessions (which can be verified using the command show policy-map type inspect zone-pair NAME sessions).But again, ZBFW is pretty unpredictable and at times things we think should work do not end up working because of some other conflicts in the config, etc.
Thanks and Regards,
Prapanch
Hi Laurent,
It appears as though you might be running into bug #CSCta00183. Do you see drops like this in the ip inspect logs :
*Jun  5 16:09:38.583: %FW-6-DROP_PKT: Dropping Unknown-l4 session 20.20.20.3:0 20.20.20.1:0 on zone-pair out-self class class-default due to  DROP action found in policy-map with ip ident 0
Atri
Community Member
We just got a new router with Zone Firewall functionality. I was considering using the feature or not and asking these same questions. If gre and esp are not in the list of protocols that can be matched, I assume the only option is to use an ACL. If the protocols must be specified in an ACL, why not just apply the ACL to the interface? I don't see the benefit of using Zone Firewall in my case, which is similar to the posted case. Please enlighten me if possible.
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a0080a63b94.shtml#topic1w
I found this Cisco site that offers a solution for problem "Unable to pass VPN Traffic". The commands appear to inspect all traffic specified in an ACL. Does anyone know if invoking the Zone Firewall with the "class-map type inspect" commands cause anything more indepth to happen than an ACL is queried? In the case from the link above the ACL is permit IP source to destination address only, which is not more indepth than the ACL already does? If not I don't see a need to use Zone Firewall in the case of DMVPN unless you have ACL's on your private and public and possibly DMZ segments and you need return holes established. Anyone have any insight on this? I'm new to Zone based Firewall.
Mike
6796
