Hello, I am in the process of migrating our voice suite from cisco to a 3rd party phone provider and am looking for tools to help identify call handlers in use and export them efficiently. Currently we have a Unity configuration that is outdated and ...
Hey GuysFor a Lab device I've got a cbs350-24p-4x. With it's 4 TenGigabitEthernet ports I'd like to use port TE1/0/1-2 for lacp to my firewall and with TE1/0/3-4 ports I'd like to connect to my vsphere ESXI host.The Switch is running on the latest FW...
I have a customer who uses Cisco SPA502G phones, from 5 months ago in October 2023, they have been complaining that their phones have been rebooting themselves from time to time.The Reboot History under Info page shows that the Reboot Reason was Syst...
HelloFor a short time now, my LTE connection in the Cisco router has been breaking down repeatedly. This is very annoying because the VPN tunnel used is always gone. Unfortunately I can't do much with the logging messages. these messages are shown af...
I enabled SNR on a users line. Works fine.Customer does not like that other phones show the option under CME Services URL>My Phone APPS> Single Number Reach, even when the phone line is not programmed to allow SNR. Is the SNR option something that ...
Scenario,Host-A(10.10.30.3/24) connects to access port on SwitchA with various other vlans also configured via access ports. SwitchA connects on a Trunk port to a CatSwitch. Firepower inside ½ interface trunks to CatSwitch. On The CatSwitch 3 vlans; ...
We had some changes recently and have inherited an aging campus infrastructure. Being primarily from service provider background, we are slowly exploring the Campus ecosystem. Does it make sense to use the same devices used in SP for Campus? Core and...
H, i have this msg error in CMM logs " django.db.utils.IntegrityError: duplicate key value violates unique constraint "cmm_licensing_hostlicens_cluster_id_host_timestam_3e015b7f_uniq"Apr 17 08:20:09 cmm cmm-web_worker_1[275]: DETAIL: Key (cluster_id...
I'm running CBD2.7.1 and installed a public wildcard certificate.The following error is flashing on the top of the dashboard:"Server certificate does not contain your server address in Subject Alternative Name."Is this a bug when using wildcard certs...
Hello all, I bought a cbs350 switch to seperate my LAN to different VLANs (IoT devices, ...). I was able to create the different VLANs together with DHCP and to seperate the internet router into an own VLAN. So currently all devices are able to conne...
HI,i am trying to update my SG500 and SG 300 series switch to latest firmware. currently running in 1.3.0.62 and planning to upgrade to 1.4.11.5. i have downloaded the firmware from cisco portal sx500_fw-14115.ros. while performing i am getting an be...
