We have 2 SG350x-48 switches in a stack. and we need to add another switch. but I know that SG350x-48 is no longer sold. what are my options? these were replaced by the "Cisco Business 350 Series Managed Switches". can one of these switches be a...
I own a CBS350-8XT that is far too noisy. I even purchased a sound meter to obtain a measure and it goes up to 70db where the maximum indicated in the user manual is 41.3db. I would like to open a ticket or something for cisco to fix my unit. How sha...
Hello,I have a C1300, I use it as my IPv4 and IPv6 gateway for internal routing. It has a default gateway to another router for internet access. If I perform an IPv6 speedtest with the c1300 as my gateway for IPv6 then I get around 1Mb, this is stran...
Dear all,I just received a 350x-24. The fan is quite loud, but that isn't a problem as no one sits beside the rack.I just wondered if a noise of 49.2dB average is normal or if it is a indiaction for a hardware or config problem?The noise level was ju...
Router>Router>enRouter#conf tEnter configuration commands, one per line. End with CNTL/Z.Router(config)#Router(config)#Router(config)#Router(config)#crypto key ?decrypt Decrypt a keypair.encrypt Encrypt a keypair.export Export keysgenerate Generate n...
HelloFor a short time now, my LTE connection in the Cisco router has been breaking down repeatedly. This is very annoying because the VPN tunnel used is always gone. Unfortunately I can't do much with the logging messages. these messages are shown af...
Hello,I have an ISP router/modem, along with assignable public IP addresses for use. Leaving default VLAN1 alone (mgmt), I created VLAN10 (192.168.0.0/24) and VLAN20 (172.16.3.0/24) on the CBS350.ISP router "internal" ip 172.16.2.1/24On CBS350 port G...
I have questions in cluster settings. (1) Number of WAP devices per single point setting WAP150:4 Does the setting 'WAP150:4' indicate that a maximum of 4 WAP devices can be connected in a single cluster? (2) Registering an AP in a Created Clu...
I have several CBS350 switches running 3.4.0.17.They are showing POE faults on some of the ports.I'll use one switch as an example. It is a CBS350-24FP-4G.The POE Properties show Nominal Power = 370WAllocated Power = 13WAvailable Power = 357WSoftware...
Hi, I have Mikrotik Cloud base router its connect with cbs 100 switch (WAN) and its connect with cbs350(LAN). I am getting this error. Kindly this one is from swx side or WAN side and what's the solution. Thanks @
Hello, I am in the process of migrating our voice suite from cisco to a 3rd party phone provider and am looking for tools to help identify call handlers in use and export them efficiently. Currently we have a Unity configuration that is outdated and ...
Hey GuysFor a Lab device I've got a cbs350-24p-4x. With it's 4 TenGigabitEthernet ports I'd like to use port TE1/0/1-2 for lacp to my firewall and with TE1/0/3-4 ports I'd like to connect to my vsphere ESXI host.The Switch is running on the latest FW...
I have a customer who uses Cisco SPA502G phones, from 5 months ago in October 2023, they have been complaining that their phones have been rebooting themselves from time to time.The Reboot History under Info page shows that the Reboot Reason was Syst...
