11-18-2006 03:08 PM - edited 03-05-2019 12:54 PM
Here's what's happeneing: Basically, i Hyperterminal'ed into it, updated the IOS, everything is dandy. Now however, when the switch boots, amber lights come up randomly on Ports 1-4,7,9-12, and 14. Also, when i attempt to plug in a node, the switch just sits there and gives no physical (or CLI) indication that it knows what's going to on.
IT is also spitting out these errors on differnt ports constantly. I can't upgrade the IOS again becuase i can't get an IP Address to TFTP it. Any suggestions would be welcomed.
*Mar 1 00:42:39: %LINK-4-ERROR: FastEthernet0/1 is experiencing errors
*Mar 1 00:43:37: %LINK-3-UPDOWN: Interface FastEthernet0/5, changed state to up
*Mar 1 00:43:38: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/
11-19-2006 01:39 AM
i suggest if you have a copy of the old soft, download it via console using xmodem for example.
you just need to enter rom mode.
11-19-2006 09:47 AM
I don't have a copy of the old software...doh!
11-19-2006 08:30 PM
if you have an other functionning switch, copy the soft of that switch.
you can try also other new soft. or even to make serial download again of the current soft.
but first be sure your soft is not corrupted : \MD5 check.
