03-16-2006 08:45 AM - edited 03-05-2019 11:48 AM
On the sup720 there are 2 fiber ports and one other port that looks like a fast Ethernet port. However, to use this FastE do I configure this port as a vlan?
What is the significance of this interface?
03-16-2006 09:06 AM
Hi Sandra,
the sup270 has two Gigabit Ethernet ports, one Small Form-Factor Pluggable (SFP) and one selectable SFP or 10/100/100 RJ-45, so only two of the three ports can be active at any one point in time.
You can configure this as documented below
CatOS:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_8_5/confg_gd/ether.htm#wp1038398
IOS:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/swcg/sup720.htm#wp1051988
HTH,
Bobby
*Please rate helpful posts
03-16-2006 11:20 AM
Hi Bobby,
right now I'm using both gigabit ethernet ports.
one primary and the other a backup for that fiber link. If i understand you correctly, since I'm using both ports I can't use the third, which I needed for another connection.
03-16-2006 01:31 PM
Hi Sandra,
That's correct, you can't use the third port if you're already using two.
regards,
Bobby
