boot problems on a 3600
hi
we have a 3600 started from flash (without memory card) and after erase startup-conf i cant take console. Can anybody help me?
thanks
2 ACCEPTED SOLUTIONS
Re: boot problems on a 3600
what is that you get ehn you connect to console
Bronze
make sure you have the right baud. You may have had it set higher than 9600 before the erase of the config.
Use 9600 and see if that helps.
Bronze
111
