Cisco 1701 adsl not connecting??
sunny.xpander
Hey guys,
I'm using sdm to do a quick setup on my router i managed to setup using the quick wizard and i setup the pppoe connection but i don't think it's connecting because i am getting dns error when i try to browse. Am i missing a step??? Do i need to open something after i create the connection???
Where can i get a status to see what the problem is?
11 Replies 11
globalnettech
Level 5
Level 5
can you try and access a website by using it's IP address, eg.:
http://64.236.24.12/
If you gain access, the problem indeed is likely related to the DNS part of your configuration. Can you post the configuration of your 1701 ?
GNT
I will try that when i get back, i doubt it will be a dns issue i was unsuccessful when i try pinging external addresses.
How do i get a print of the configuration in command line?
I can not ping by name or ip to anywhere. I don't think the pppoe connection i setup is working...
Do i need to open access anywhere??
Please help i can not get this working..
If you know how to connect to your router via console cable do so and enter the enable mode via the following steps:
Router> enable
(It might ask for a password if you have configured one)
Router# show run
When you issue the show run command it will print the current running configuration of the router. We would like you to post that configuraiton here so we can do a sanity check on it.
In case you do not know how to connect to the console port you can use the procedure described here:
http://www.cisco.com/en/US/products/hw/routers/ps380/products_installation_guide_chapter09186a0080099e67.html#wp1015367
Ok guys this is driving me mad please tell me what i am missing.
I have reseted to default.
Access router via ip and used SDM software to configure the basics such as DHCP,pppoe and so on.
This is the print.
Building configuration...
Current configuration : 2469 bytes
! Last configuration change at 14:12:33 PCTimeZ Fri Jun 2 2006
! NVRAM config last updated at 14:12:42 PCTimeZ Fri Jun 2 2006
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname gateway
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console critical
enable secret xxxx
username root privilege 15 password xxxx
clock timezone PCTimeZone 0
no aaa new-model
ip subnet-zero
no ip source-route
ip dhcp excluded-address 10.10.10.1 10.10.10.19
ip dhcp excluded-address 10.10.10.41 10.10.10.254
ip dhcp pool sdm-pool1
network 10.10.10.0 255.255.255.0
default-router 10.10.10.254
ip tcp synwait-time 10
ip domain name domain.com
ip name-server 203.0.178.191
no ip bootp server
ip cef
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
no scripting tcl init
no scripting tcl encdir
no crypto isakmp enable
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description Adsl PPPoe
pvc 8/35
pppoe-client dial-pool-number 1
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
interface FastEthernet0
description $FW_INSIDE$$ETH-LAN$
ip address 10.10.10.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
ip tcp adjust-mss 1452
speed auto
interface Dialer0
ip address negotiated
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username user@isp.net.au password xxxx
ip classless
ip http server
ip http authentication local
ip http secure-server
logging trap debugging
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 4000 1000
scheduler interval 500
end
gateway#
Can anyone tell me what i am missing please.
My configuration is in my previous post.
Your router is handing out private IP address for DHCP. Is your service provider providing a NAT translation that changes the non-routable 10.10.10.x ip address to a routable address?
Yes they do.
As another troubleshooting step, do a show ip interface brief command (if your router and IOS support that command) and check the operating status of your interfaces. In a perfect world your ATM interface, ATM sub-interface and your ethernet interface should all be in an up/up condition.
yes both
Lan and atm is up.
Thank you for your help guys i have managed to get it working.
