Cisco 4-Port ISDN-BRI Network Module
what does the BRI mean?
I have this module in a 2600 series router. Can it be used for basic LAN connection (like a hub)?
Green
Re: Cisco 4-Port ISDN-BRI Network Module
First, to answer your question: No, you cannot.
ISDN is a Telco technology and protocol suite.
"BRI" stands for "Basic Rate Interface," also described as "2B+D" for two Bearer channels and a "D" channel, which is used for control signaling in some configurations, and additional bandwidth in others.
Max throughput is either 128K (2 X 56K or 64Kbps per channel) or 144Kbps (2B+16K that may be available in the D channel depending on your config.
ISDN requires an intermediate telco-style switch between the clients and can't be used back-to-back directly.
Good Luck
Scott
Hall of Fame Super Silver
Anthony
To supplement the good answer from Scott, you ask:"Can it be used for basic LAN connection". Scott correctly responds that it can not. This is because BRI (and ISDN in general) is a WAN technology and not a LAN technology.
Rick
455
