Connection between 2960G-24TC-L and 2950G-24-EI
i want to connect 2960G-24TC-L with 04
2960-24TC-L and one(01) 2950G-24-EI, the four(04) ports uplinks are reserved to connect all four(2960-24TC-L),my question it's possible to connect this 2950G-24-EI with using the GBIC 1000T to one of 20 ports Giga of the 29 2960G-24TC-L.
Thank you!
1 ACCEPTED SOLUTION
Re: Connection between 2960G-24TC-L and 2950G-24-EI
I don't see why not as long as you are within the proper cable length for copper Ethernet.
ok,
thank you
205
