Copy from flash to host on LAN?
I'm connecting to a remote location and need to copy a few files off the flash to a host on the LAN so I can update them. I know to go from the lan to the flash I can use
copy tftp://host/file
but is it possible to do the same thing in reverse?
1 ACCEPTED SOLUTION
Re: Copy from flash to host on LAN?
Hi Richard,
To Copy file from flash to tftp
Run this command copy flash tftp
check out the below link for more information
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00800a6744.shtml
Hope that helps out your query !!
Ganesh.H
it seems like what I need is;
copy flash:[file] tftp://[host]
Hi Richard,
Ganesh.H
Hall of Fame Super Gold
Hi Richard,
Don't forget to copy the vlan.dat file (if you are using more than the default VLAN 1).
463
