Difference between sh ip bgp & sh ip route? BGP tables and main routing table.
sh ip bgp :::: loc-rib ?
sh ip bgp nei x.x.x.x advertised-routes : adj-rib-in.
sh ip bgp nei x.x.x.x recieved-routes : adj-rib-out.
sh ip bgp nei x.x.x.x routes : loc-rib ?
sh ip route = rib ? if yes does it mean its loc-rib ?
so in a given router with bgp running, will there be 5 tables (sh ip bgp; adj-rib-in; loc-rib;adj-rib-out; sh ip route) ? if yes where are they saved ?
Everyone's tags (1)
Hi, sh ip route is showing
sh ip route is showing you the best routes among all routing protocols plus static and directly connected routes.
sh ip bgp is showing only prefixes contained in BGP database.
That's the basic difference.
Regarding the three BGP database sections, see here http://www.tcpipguide.com/free/t_BGPRouteStorageandAdvertisementandBGPRoutingInform-2.htm
for an explanation.
Best regards,
Milan
Silver
sh ip bgp shows the BGP table
sh ip bgp
shows the BGP table (where are stored info coming from BGP update)
shows networks that your router will advertise to a specific neighbor
shows advertisement received from a specific neighbor;  networks (NLRI) filtered with route-map distribute-list,... are included  (Inbound soft reconfiguration must be enabled)
shows only routes sent by a specific neighbor and not filtered or discarded (i.s accepted)
sh ip route
show routing table; it contains the best route for each network (best is first of all the lowest administrative distance, then the lowest metric)
Bye,
enrico.
PS please rate if useful
Take a look at this thread,
Take a look at this thread, it may help you:
https://supportforums.cisco.com/discussion/9882981/bgp-adj-rib-loc-rib-adj-rib-out
1532
