GBIC WS-G5486 Connectivity issue
Dear All,
We have a problem with the GBIC WS-G5486 regarding its connectivity with the
fiber cables as explained below:
The problem simply is that the link distance is less than 1 Km, and the
Fiber Optic cable is single-mode, i'm installing the GBIC both ends in
7206-VXR with NPE-G1 router, the status of the interface in one side is
up/up and the other end is down/down...!!! when i disconnect the cable from
the down/down side, the other end becomes down/down, which means that there
is some kind of signaling reaches that end.
Any Idea can help us to resolve this problem??
Thanks in advance...
Best regards,,
Magdy Hossein
Re: GBIC WS-G5486 Connectivity issue
Hello Magdy,
You seem to have an unidirectional link condition. I know of two reasons for that:
1) one of the fibers of the pair is broken
2) one GBIC transmitter and/or receiver is broken
Regarding option 1):
Can you swap the fibers and see whether the interface down/down swaps sides? Replace the fiber in this case.
Regarding option 2):
In case the test above reveals no change in up/up and down/down, then you might have a GBIC problem. Either the receiver on the down/down side or the transmitter on the up/up side is broken. So replace a GBIC at a time until you get the link working.
Hope this helps! Please rate all posts.
Regards, Martin
Silver
Madgy,
Try this interface command on both routers:
'no negotiation auto'
If that doesnt help, then you either have a faulty GBIC on one end or a bad strand of fiber.
Silver
Also:
Insure that you have: 'media-type gbic'
VIP Purple
in addition to the other suggestions, there have been a couple of posts here lately describing exactly the same thing. I had an issue which is very similar to your while helping a client with new 3750 switches. How we eventually got it resolved was by unplugging the fiber cable, entering the command ´speed nonegotiate´, and plugging the cable back it. The interface came up after that...
GP
160
