02-27-2008 08:13 AM - edited 03-05-2019 09:24 PM
Should be an easy one...
I need to get an idea of how much traffic is passing over a gi port on my 4006, over an 8 hour period. Any ideas?
Solved! Go to Solution.
02-27-2008 01:55 PM
Enable SNMP on the switch and then follow the config guide for MRTG. It will walk you through the steps for getting it up and running
Brandon
02-27-2008 01:41 PM
Here's one free option.
Hope this helps. If so, please rate the post.
Brandon
02-27-2008 01:43 PM
I am somewhat familiar with mtrg, but I'm not sure how I get that setup for my 4006 Switch...
02-27-2008 01:55 PM
Brandon
02-28-2008 11:43 AM
Another option, if just one (or few) time(s), your can access the box at the beginning and end of the 8 hour period, and the needed interface stats are available; just note bytes counts at both times, the deltas answer your question.
02-29-2008 06:43 AM
Thanks guys. I am going to setup MRTG so I have a long term solution. I already get this info from Network Assistant on my 3550's, but the 4006 won't play...
