Interface in shutdown, Link-LED stays on.
0tgemmecker
I shutted down the GigabitEthernet-I/F on a cisco3845-router. The Link-LED stay on. Shouldn`t the Link-LED went off when the Interface is Administratly down?
The other side off the Cable is connected to a Catalyst. Does anybody have a expaination for this behavior?
5 Replies 5
Postal4x4
Are you sure it was not the other interface of teh 3845 that was shut?
0tgemmecker
Yes, I am sure. It's the correct Interface.
Are you using the CLI to issue the command? The reason I ask is I have had instances where issuing the command via a GUI did not acutally apply the command.
This is rather peculiar...
Chad Peterson
Is the link light amber or green?
I would expect an up link to be green, down link no light, and admin down to be amber.
The link lights are green - on both sides (on the cisco3845 and the calalyst ws-x5225-module)
