Community Member
interface trunk auto
How do I remove auto from an interface? I have a port that is set to switchport mode dynamic desirable. When I try to set the interface to swicthport mode trunk I get command rejected. An interface whose trunk encapsulation is "Auto" can not be configured to "trunk" mode.
DJ
Re: interface trunk auto
Hi Donna,
You should select an encapsulation protocol first, dot1q or isl.
switchport trunk encapsulation [dot1q | isl]
switchport mode trunk
Cheers:
Istvan
Community Member
Thanks! Worked great. I would check out as solved my problem, but it didn't give me the option.
DJ
You're welcome Donna!
Cheers:
Istvan
547
